Coupon code for 20% off membership: SPRING20
Results 1 to 4 of 4
Thread: Installing a new metal lathe chuck.
    mr_modify1's Avatar
    Nov 2021
    mr_modify1's Tools
    Save 20% on Membership
  2. The Following 2 Users Say Thank You to mr_modify1 For This Useful Post:
    EnginePaul (Jan 30, 2023), nova_robotics (Jan 26, 2023)
    Sep 2018
    nova_robotics's Tools
    Excellent work good sir. 1 thou is perfectly acceptable for a 3 jaw chuck. I did a similar process of marking and matching my chucks to minimize runout. It worked well.
    Berkshire UK
    thehomeengineer's Tools
    Hi
    I hope you don’t mind me putting my two pennies worth in. I noticed you didn’t machine the backplate true to the spindle. When I replace a chuck I always face up the mating face of the backplate and turn the register diameter 4/5 thou smaller than the register on the chuck. This then allows the chuck to be centred perfectly by lightly tapping the chuck true, before fully tightening the bolts down. This ensures there is no runout of the chuck. I have always used this method and the chuck always run with zero runout.
    The Home Engineer
  5. The Following 2 Users Say Thank You to thehomeengineer For This Useful Post:
    EnginePaul (Jan 30, 2023), olderdan (Jan 28, 2023)
    olderdan's Tools
    Home engineer that is a good method and the one I have always used. Works well for older chucks that have some wear, Thanks for posting.
  7. The Following User Says Thank You to olderdan For This Useful Post:
    thehomeengineer (Jan 28, 2023)
