Results 1 to 9 of 9
Thread: Installing A VFD/VSD On A Drill Press
    Supporting Member The Hobby Machinist NZ's Avatar
    Jan 2023
    New Zealand
    The Hobby Machinist NZ's Tools
    A lot of the VFDs are meant to be mounted in an enclosure because they have exposed terminals. In this video I discuss installing a VFD on my drill press and I show how I enclosed the VFD for safety.
  2. The Following 2 Users Say Thank You to The Hobby Machinist NZ For This Useful Post:
    ductape (Mar 2, 2023), nova_robotics (Mar 1, 2023)
    meyer77's Avatar
    Feb 2019
    meyer77's Tools
    Nice Job!
    Is there a VFD for 220 single phase in to 220 single phase out?
    Dec 2022
    Midwest US
    ductape's Tools
    Quote Originally Posted by meyer77 View Post
    Nice Job!
    Not really.
    VFDs are generally not compatible with capacitor start or universal motors. Most modern single phase motors are one of these type. There may be some hack out there to make it work, but it would almost certainly be bad for the motor over time.
    Jan 2023
    New Zealand
    Nice Job!
    When I was looking into VFDs I did not see any with single phase outputs. Someone else may correct me, but as far as I know these are either single or 3 phase in, and only 3 phase out.
    meyer77's Avatar
    Feb 2019
    meyer77's Tools
    I did a little research today and there is a hack to take out the capacitor start circuit and another. The best route costs about $325 that includes a VFD and a three phase motor
    Supporting Member 2gsg2_muc's Avatar
    Aug 2021
    Munich
    2gsg2_muc's Tools
    Nice job.
    I have two questions regarding the installation.
    Do you have openings for ais cooling in the case?
    Dit you install a extra RPM meter in your drill?
    I made a similar installation with a VFD in a drilling machine, the spindle was driven by a belt 1:1, so the spinle hat the same spped as the motor. So I removed the control box from the VFD and installed the controller in the front panel. The conection was solved by a extension cable of a leght of 10 inches. I used only a safety switch for emergency stop, which can barke the motor instandly.
  8. #7
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    Quote Originally Posted by The Hobby Machinist NZ View Post
    Yes, that's generally the case that most are 1ph or 3ph in and 3ph out. I have never done it, but I assume you could somehow run a universal motor off of a VFD. I imagine that would not be very good thing for either the motor or the VFD, nor the best way to vary the speed of single phase motor.
    Here's a good video explaining the operation of a VFD. It covers a few of the basics of electronics (what diodes do, for example), so it's a good lesson even if you aren't electrically savvy. It still goes into a good bit of detail, though, so it's useful even for guys with oscilloscopes on their benches.
    For topical application, only. Not to be taken internally or used in com-
    bination with other drugs or alcohol, except as directed by your shaman.
    Do not operate heavy equipment, unless you actually know how to.
  9. The Following User Says Thank You to schuylergrace For This Useful Post:
    nova_robotics (Mar 7, 2023)
  10. #8
    Sep 2018
    nova_robotics's Tools
    Quote Originally Posted by schuylergrace View Post
    Yes! You can! It actually doesn't make much of a difference to the motor. The universal motor will just happily continue chugging along as if nothing changed as you adjust the frequency up and down. You're probably right about it beating up the snubbers in the VFD. If you could somehow get in there and reprogram the microcontroller on one of those consumer level VFDs I bet you could get it to do PWM for speed control simultaneously on three different motors. That might be an interesting project.
  11. The Following User Says Thank You to nova_robotics For This Useful Post:
    schuylergrace (Mar 7, 2023)
  12. #9
    meyer77's Avatar
    Feb 2019
    meyer77's Tools
    I did some research and have come to the conclusion that a three phase motor and a VFD are the way to go, I can get both for less than $300.00.
