Thread: Integrated Voltage—Current Monitoring and Control of Gas Metal Arc Weld Magnetic Ball
Hybrid View
    Supporting Member MOST's Avatar
    Aug 2017
    MOST's Tools
    Integrated Voltage—Current Monitoring and Control of Gas Metal Arc Weld Magnetic Ball-Jointed Open Source 3-D Printer
    To provide process optimization of metal fabricating self-replicating rapid prototyper (RepRap) 3-D printers requires a low-cost sensor and data logger system to measure current (I) and voltage (V) of the gas metal arc welders (GMAW). This paper builds on previous open-source hardware development to provide a real-time measurement of welder I-V where the measuring circuit is connected to two analog inputs of the Arduino that is used to control the 3-D printer itself. Franklin firmware accessed through a web interface that is used to control the printer allows storing the measured values and downloading those stored readings to the user’s computer. To test this custom current and voltage monitoring device this study reports on its use on an upgraded all metal RepRap during the printing of aluminum alloy (ER1100, ER4043, ER4943, ER4047, and ER5356). The voltage and current data were analyzed on a per alloy basis and also layer-by-layer in order to evaluate the device’s efficacy as a monitoring device for 3-D printing and the results of the integrated design are discussed.
    Integrated Voltage—Current Monitoring and Control of Gas Metal Arc Weld Magnetic Ball-300px-magneto.jpg
    For more information, visit the project's page on Appropedia:
    https://www.appropedia.org/Integrate...ce_3-D_Printer
    Download the paper here:
    https://www.academia.edu/17673716/In...ce_3-D_Printer
  2. The Following 4 Users Say Thank You to MOST For This Useful Post:
    Altair (Nov 16, 2019), darkoford (Nov 27, 2019), Jon (Nov 21, 2019), mwmkravchenko (Nov 26, 2019)
