Results 1 to 5 of 5
Thread: Interlocking concrete blocks - GIF
Hybrid View
  2. The Following 4 Users Say Thank You to Altair For This Useful Post:
    carloski (Aug 5, 2022), durrelltn (Aug 8, 2022), mwmkravchenko (Aug 5, 2022), nova_robotics (Aug 5, 2022)
    Those would be better if they were case with a vertical hole through the and an indentation in each end to match up with the holes then rebar could be driven down through them to help with vertical stabilization for taller walls
    May 2015
    Tasmania, Australia
    Bony's Tools
    A good idea nevertheless. Maybe there are T shaped ones to allow for building columns to be constructed with spacing appropriate for the height.
    Sep 2020
    Where can these interlocking blocks be purchased? I’ve got the perfect project for gheee blocks.
    May 2015
    Tasmania, Australia
    Bony's Tools
    You would want to get the first course perfectly level too, as the likelihood of the wall not being vertical increases greatly as height increases. That appears to be a major disadvantage for this type of construction.
