Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: KanDo Won't Twist Clamps....Brass Copper Steel Rivets
    Supporting Member will52100's Avatar
    Oct 2015
    Bassfield, MS
    will52100's Tools
    Very cool, love the brass. You've got me wanting to make some, where can I find patterns for the arms? Thanks.
    courtneyknives.net
  2. #12
    jjr2001's Tools
    Here is a set of plans that are similar to what I made. Complete .pdf with drawing and dimensions.
    https://lphscadd.wikispaces.com/file...p+Assembly.pdf
    Cheers, JR
  3. The Following User Says Thank You to jjr2001 For This Useful Post:
    will52100 (Jun 8, 2018)
  4. #13
    Oct 2015
    Bassfield, MS
    will52100's Tools
    Cool, thanks. I did a quick google search and didn't come up with much. Got a real small set and am wanting larger ones now, plus it looks like an interesting project.
    courtneyknives.net
  5. The Following User Says Thank You to will52100 For This Useful Post:
    jjr2001 (Jun 7, 2018)
  6. #14
    jjr2001's Tools
    It is a good project. The sides can be fastened with rivets,screws and nuts, or even threaded rod with cap nuts.
    Very useful in the shop when completed and the jaws can be customized for the kind of work you do.
    Quite versatile old school clamps.
    Cheers, JR
  7. The Following User Says Thank You to jjr2001 For This Useful Post:
  8. #15
    Jul 2017
    Port Elizabet, SA
    garage nut's Tools
    Tried to download that PDF several times.
    Please help with some basic dimensions, distance to pivot points and material thickness, the rest can be figured out
  9. #16
    jjr2001's Tools
    Try this link:
    Lumberjoe made me do it! - by oldnovice @ LumberJocks.com ~ woodworking community
    There is a link to download the same .pdf that I posted earlier.
    I am able to download from both links.
    One thing to try is to use a different browser to download the file.
    This lumberjocks has some good info.
    Cheers, JR
  10. The Following 2 Users Say Thank You to jjr2001 For This Useful Post:
    garage nut (Jun 9, 2018), will52100 (Jun 10, 2018)
  11. #17
    Jul 2017
    Port Elizabet, SA
    garage nut's Tools
    Worked with different browser.
    I see you have an extra kick where the jaw blocks fit in.
  12. The Following User Says Thank You to garage nut For This Useful Post:
    jjr2001 (Jun 10, 2018)
  13. #18
    jjr2001's Tools
    Just a little design variation in the clamp. Still works the same but might just look a bit better.
    Cheers, JR
  14. #19
    Aug 2016
    wizard69's Tools
    Nice work on the brass clamps!
    They would be nice for welding projects but would never look the same afterwards. The idea being that brass should resist splatter.
  15. The Following User Says Thank You to wizard69 For This Useful Post:
    jjr2001 (Oct 20, 2018)
  16. #20
    jjr2001's Tools
    Thanks Wizard69, I had in mind using them where I did not want to scratch the finish on the parts.
    By replacing the steel screws and nuts they would be great in areas of high magnetism.
    I think I would just make up another set out of steel for welding!
    Cheers, JR
    Download plans for clamps.
