Thread: Keyway clean up file
    Ordinarily I hold files as tools that are a cut above being subjected to my ingrained nature to modify just about any tool to suit my needs.
    However, a sprocket I had cut a keyway in still lacked just a scooch more depth after broaching it on my lathe using the carriage like a shaper. I could have returned it to the lathe but I already had another setup in it so I decided to just file out the remaining bit the only problem was to do this I either had to use a much smaller narrower file than the keyway or transform another file into a special purpose tool.
    At least it was an older file but still sharp
    500 Tool Plans
  2. The Following 5 Users Say Thank You to Frank S For This Useful Post:
    baja (Aug 17, 2022), Home-PC (Aug 15, 2022), Jon (Aug 18, 2022), Metallurg33 (Aug 21, 2022), Scotty1 (Aug 13, 2022)
    Thanks Frank S! We've added your Keyway Cleanup File to our Filing category,
