Originally Posted by
LMMasterMariner
I was broaching keyways by moving the carriage (elbow grease again) back and forth and for the first cuts where I already had the hole, I could increase 0.06 mm for each pass and near the end I was able to increase 0.01 mm per pass. Also from time to time made several passes without increments due to elasticity of gear material. It took me about 5 minutes to make keyway in a gear (#45 steel, thickness 15 mm, hole I.D. 20mm, key 6 x 6 mm; little bit more than 3 mm in gear keyway)
Cheers
LMMasterMariner
