Results 1 to 5 of 5
Thread: Large cylinder roller jack for valve positioning - GIF
    Large cylinder roller jack for valve positioning.
    Spinning/rolling gas cylinders to transport them - video
    Gas cylinder welding fire - GIF
  2. The Following 5 Users Say Thank You to Jon For This Useful Post:
    baja (May 26, 2019), Scotsman Hosie (May 25, 2019), Seedtick (May 25, 2019), that_other_guy (Jun 1, 2019), tonyfoale (May 26, 2019)
    ?! Because they snore while sleeping on their sides?
    davesrepair (Jul 3, 2024)
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    How much vino is in those cans?
  6. The Following User Says Thank You to NortonDommi For This Useful Post:
    Toolmaker51 (Feb 4, 2021)
    Aug 2012
    Australia
    desbromilow's Tools
    you may find it's to stop internal components "brinelling" by sitting in one orientation too long. When we store electric motors, or things with bearings we have a schedule where we rotate the shafts every quarter so the bearings won't "settle" and cause divots in the races. Generators and other similar rotating machines have the same issues with material creep causing small deformities under gravity, and then when the unit is brought into service, those small deformities cause premature wear and failure of the bearings, etc.
    Those units look like large accumulators, which will have internal components such as metallic bladders, and perhaps some oils. by rotating them periodically it may be preventing localised corrosion to the interior of the shell caused by condensation, etc, or sag in the bladder. A reliability engineer or technician will know more than I about that.
  8. The Following User Says Thank You to desbromilow For This Useful Post:
    Frank S (Jul 3, 2024)
    Dec 2017
    NeiljohnUK's Tools
    Liquefied gas, possibly Chlorine, they have valve's often several, to allow either gas withdrawal or liquid discharge, the latter with a dip-tube that need's to correctly orientated. https://www.lutz-jesco.com/en/produc...ne-barrel.html
