Get 500+ homemade tool plans, tool build guides, ebooks, and much more.
Thread: Lathe chamfering tool that gets into tight inside bores.
    Marion, Iowa
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    metric_taper's Tools
    I use Style D and E brazed ceramic lathe tools, as well hand ground HSS tool bits on my lathes for chamfering operations. The problem is the lack of clearance with all these tools if you want to chamfer the inside edge of a hole drilled using the lathe, especially if it's a small bore.
    So I was searching on the internet for a tool that I could purchase, when I hit on this guys web site.
    https://docsmachine.com/projects/misc/chamfertool.html
    I procured some HSS 9.5mm blanks from eBay. I used the side of my surface grinder wheel to put the 45 degree point (90 degree included angle).
    I used the 5C spin indexer for this operation;
    Lathe chamfering tool that gets into tight inside bores.-45-degree-point.jpg
    Pretty much I used the same process to grind the cutting edge to the HSS blank using a 5C square block, this ensures both ground cutters are in the same plane so when installed in the quick change holder, I can rotate to square to the work or parallel to the spindle;
    Lathe chamfering tool that gets into tight inside bores.-5c-collet-block-grinder.jpg
    I use the 400 and 100 series of quick change tool holders between my small and large lathe so I made 2 of these chamfer cutting tool bits.
    Lathe chamfering tool that gets into tight inside bores.-402-tool-holder.jpg
    I'm very pleased with how these work.
    45 Best Harbor Freight Tool Modifications
  2. The Following 5 Users Say Thank You to metric_taper For This Useful Post:
    Crossslide (05-29-2020), Jon (06-04-2020), Paul Jones (05-29-2020), rossbotics (06-01-2020), Seedtick (05-29-2020)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    500+ Homemade Tool Plans
    Thanks metric_taper! We've added your Small Bore Chamfering Tool to our Machining category,
    as well as to your builder page: metric_taper's Homemade Tools. Your receipt:
    Forge Build Guide
    Post your reply!
    eBooks for Supporters
