Results 1 to 4 of 4
Thread: Lathe Chuck Anti-Spin Dog
Hybrid View
    May 2012
    Byron, Michigan
    astroracer's Tools
    I have a need to drill some larger diameter holes in pieces set up in the lathe chuck. I use a drill chuck on a taper in the tailstock. Over the years I have spun the chuck on the taper a few times when the drill catches in the work piece. Not a good thing but what is a guy to do?
    I had that problem tonight drilling out some 5/8" nuts with a .6195 dia. drill. All the chuck wanted to do was spin. Especially when a little bit of chatter freed it up. I needed to fix this so I could finish a job.
    I dug thru one of my scrap aluminum drawers and came up with this... A slip collar from a computer shaft.
    It fit perfectly over the nose of my drill chuck.
    I thought oh man this is doable!
    I grabbed another piece of scrap aluminum. 3/16 thick, laid out a pattern off the top of my head and cut it out on the VBS. Smoothed it off with a flap disc and some ScotchBrite and here it is.
    Drilled and tapped three holes in the collar and dog and bolted them together.
    See next post
  2. The Following 3 Users Say Thank You to astroracer For This Useful Post:
    Hotz (Jun 12, 2015), Jon (Jun 11, 2015), kbalch (Jun 15, 2015)
    May 2012
    Byron, Michigan
    astroracer's Tools
    The dog worked like a charm, I got the nuts drilled out without a hitch (or a spinning chuck) and was pretty pleased with the work I did tonight.
    These were the pieces I was drilling out. Made them a heavy slip fit over the bolt to use as axles for a wagon I am building
    Mark
  4. The Following 4 Users Say Thank You to astroracer For This Useful Post:
    Hotz (Jun 12, 2015), Jon (Jun 11, 2015), Paul Jones (Jun 11, 2015), PJs (Jun 16, 2015)
    Good idea, astroracer! Thanks for posting.
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Mark! I've added your Lathe Chuck Anti-Spin Dog to our Lathe Accessories category, as well as to your builder page: astroracer's Homemade Tools. Your receipt:
