Results 1 to 6 of 6
Thread: lathe follower rest
    bouboulas's Avatar
    GREECE
    bouboulas's Tools
    lathe follower rest
    Hi everybody for once more!
    Sometimes we need to work on our lathe small diameter shaft that when we work on them they bend and we get the wrong diameter of them. For this reason I made a lathe follower rest. In the following video you will see how I made it.
  2. The Following 5 Users Say Thank You to bouboulas For This Useful Post:
    DIYer (Oct 22, 2021), Frank S (Oct 21, 2021), Jon (Oct 28, 2021), Ralphxyz (Oct 21, 2021), WmRMeyers (Oct 21, 2021)
    I have that exact same model Le Blond lathe and for a while now I have been thinking about making a follow steady for it. I may make a variant of yours for mine, but good job, I would put the locking screws on the opposite side though away from the chuck less chance of crashing into them
    bouboulas (Oct 22, 2021)
    Thanks bouboulas! We've added your Lathe Follower Rest to our Lathe Accessories category,
    as well as to your builder page: bouboulas's Homemade Tools. Your receipt:
    bouboulas's Avatar
    GREECE
    bouboulas's Tools
    Thank you my friend
    I think it is better to have it close to the chuck for better support of
    the shaft
    Quote Originally Posted by bouboulas View Post
    Thank you my friend
    the shaft
    What I was talking about were the 2 socket head screws on the sides, having them on the side nearest the chuck means you have to stop rotation before you can safely adjust them or even re tighten should they become loose or as the brass buttons show some wear. Putting them on the opposite side does not change the relationship of the support screws it simply gets your hand out from between the chuck and the follow steady.
    be safe my friend.
    bouboulas (Oct 23, 2021)
  10. #6
    bouboulas's Avatar
    GREECE
    bouboulas's Tools
    be safe my friend.
    Yes now I understand you.You have right ! It is better from the other side
