Results 1 to 7 of 7
Thread: Lathe for home metal with a vertical drill
    Oct 2017
    Eloy Workshop's Tools
  2. The Following 25 Users Say Thank You to Eloy Workshop For This Useful Post:
    12L14 (Jul 31, 2019), 57_210 (Jan 5, 2024), Altair (Nov 27, 2018), AmateurMachinist (Apr 1, 2019), Andyt (May 10, 2019), baja (Jun 5, 2019), blkadder (Apr 2, 2019), butlerandrew (Oct 22, 2025), emu roo (Jul 12, 2024), EnginePaul (Nov 7, 2018), Frank S (Nov 5, 2018), Jon (Nov 5, 2018), JRock (Nov 5, 2018), kess (Jan 5, 2024), MeJasonT (May 10, 2019), Moby Duck (Jun 25, 2021), mr mikey (May 25, 2023), PJs (Nov 6, 2018), ranald (Jun 6, 2019), rossbotics (Nov 5, 2018), Scotsman Hosie (Feb 8, 2019), Scotty1 (Nov 6, 2018), Seedtick (Nov 5, 2018), suther51 (Feb 8, 2019), Texf1 (Feb 11, 2019)
    There have been times in my past when i didn't have access to a lathe where I was at the time. so make do's had to be done I've used a hand drill a vice and a grinder to make do sometimes. This drill press conversion is a great work around.
    Thanks Eloy Workshop! We've added your Lathe to our Lathes category,
    as well as to your builder page: Eloy Workshop's Homemade Tools. Your receipt:
    Daturat100r's Avatar
    Jul 2017
    Waimauku NZ
    Daturat100r's Tools
    Unfortunately a drill presses quill bearing arrangement is really only suited to axial loading pushing a drill through the work ,not really set up or designed for radial loads that a majority of the work done on a metal lathe imparts on the machine but 10 points for innovation
  6. The Following User Says Thank You to Daturat100r For This Useful Post:
    Jul 2016
    Mt2 Chuck? Watch that it does not come free with vibration, did you come up with a draw bar work around? Good work, thanks for posting.
    Eric
    Supporting Member blkadder's Avatar
    May 2012
    Florida, USA
    I have been thinking of doing this with a small bench top drill press that I replaced with a floor mount model. I know it is not a real replacement for a proper lathe, but I think for small jobs it would work just fine, and now you have done it. Thanks for posting.
    Ron
    ...Semper Fidelis...
  9. #7
    My first serious machine tool was a 7x30 jet mill and I made do with small lathe jobs for a couple of years before I found a nice 6" atlas lathe. In that interim time I usef the mill as a lathe able to hold round stock up to 7/8" dia. Kinda awkward position for turning work; but the mill spindle could handle heavy cuts and the maximum speed was way up there. Looking at the small R-8 spindle table top mills available today I can readily see Eloy's idea work with such a mill. Although the process ofrotating it on a "hinge" base might require the addition of some creative hoist/lever system. The remaining creative effort would be coming up with larger and more accurate bed and carriage system. Another thought on doing a lathe involved how to power an incomplete lathe when all you have is the headstock but no motor and pulley setup. Inexpensive benchtop imported drill presses usually have 4 belt drive speeds and a reversible motor. So just use the headstock and the top of the column mounted on its side on the table behind the lathe headstock. Put a pulley on a short shaft in the drill chuck and use one of those link together type belts to drive the headstock via its built in pulleys.
