Thread: Lathe indexing wheel attachment
    May 2015
    baskarz's Tools
    Found the need/ want for an indexing wheel for my hafco al250g lathe.
    Set about making my own using scraps i had laying around.
    Made the index wheel on my diy cnc from 4mm aluminium plate. It has 3 rows of holes, 30, 40 and 50 hole which will give me a wide range of divisions which should cover most if not all i would ever need.
    If i do need an odd division, i can always make a new plate.
    The spindle bore on my lathe is 26mm so i adopted an idea from bicycle head stems in order to fix the index wheel boss to the my spindle bore.
    The boss was turned from a piece of 4140 then drilled, threaded and 45° cut to form the locking clamp.
    Locating pin was turned from a piece of chromed rod out of an old photocopier and the knob turned and knurled from brass.
    Mounting is a bit crude at the moment, im working on another pin but this will do for now. I will have 2 spacer blocks to raise the pin assembly to match outer rings of holes.
    Attached Thumbnails Attached Thumbnails Lathe indexing wheel attachment-20200401_075711.jpg   Lathe indexing wheel attachment-20200401_075741.jpg   Lathe indexing wheel attachment-20200401_075408.jpg   Lathe indexing wheel attachment-20200401_075254.jpg   Lathe indexing wheel attachment-20200401_075457.jpg
    Lathe indexing wheel attachment-20200401_075515.jpg   Lathe indexing wheel attachment-20200401_080309.jpg   Lathe indexing wheel attachment-20200401_080526.jpg   Lathe indexing wheel attachment-20200401_080529.jpg
  2. The Following 14 Users Say Thank You to baskarz For This Useful Post:
    Dimitris Polychronis (Oct 1, 2022), DIYSwede (Apr 1, 2020), emu roo (Dec 30, 2025), high-side (Apr 5, 2020), Home-PC (Sep 16, 2022), Jon (Apr 1, 2020), Kevic (Apr 2, 2020), mwmkravchenko (Sep 14, 2022), NortonDommi (Apr 1, 2020), oldpastit (Apr 2, 2020), Paul Jones (Apr 2, 2020), Rangi (Apr 1, 2020), Saltfever (Apr 4, 2020), sossol (Apr 1, 2020)
    Thanks baskarz! We've added your Lathe Indexing Wheel to our Lathe Accessories category,
    as well as to your builder page: baskarz's Homemade Tools. Your receipt:
    Apr 2020
    cool man thanks
    Download plans for dividing.
  6. The Following User Says Thank You to 2wheelcharlie For This Useful Post:
