Originally Posted by
Paul Jones
Toolmaker 51 and Frank S,
Thank you for the advice. Both of you are far more experienced than I in the best way to set up machine tools. My lathe is a circa 1987 Taiwanese equivalent of the Victor and very well built with hand scraped surfaces. I like the suggested design of the extended leveling pads.
My lathe is located in my garage that has a slightly sloping floor. The lathe is located parallel with the floor slope. I use a 0.0005"/10" precision level (it took me almost two hours to first precisely adjust and self-validate this level on a surface plate - it is an extremely sensitive level and takes a while to settle in).
In my experience, the lathe ways have to be as close to leveled front to back (cross slide direction) and with the same reading at the headstock and tailstock in order to remove any minor twist in the lathe ways if you truly want to work within very tight tolerances. During the leveling process you have to take test cuts to verify the diameters over several inches from the headstock. The vertical leveling along the long axis direction of the bed is important because it makes doing cross bed leveling so much easier to set up. There are plenty of YouTube videos on doing this lathe leveling work. Don't assume the headstock is out of alignment until the lathe is very closely leveled and not an error due to lathe way twisting. From my experience, leveling the lathe ways makes the final and most critical cut along the lathe's long axis very predictable and consistently allows a constant cut diameter along the lathe long axis. The extra effort doing leveling for the lathe eliminates scraping parts and makes the final cut far more predictable and a less stressful operation when you have to hit your mark. Paul Jones
