Results 1 to 10 of 10
Thread: Lathe roller centering tool
    Nov 2015
    Italy
    rendoman's Tools
    Hi!I
    I decided to build a centering tool for lathe, after seeing some project on this forum .
    The bearing is a 20x52x12mm unit, used in 50cc 2 stroke engine for Piaggio scooter (long and short arm models), I have also some spares with lateral shield.
    The tool shank is a hex bar, I chose this profile because it's easy to be tightened on the lathe. I machined a round part for the bearing and a little step to help removal (if needed). I milled one side in order to keep the tool near the holder.
    Lathe roller centering tool-dsc05193_1600x1200.jpg Lathe roller centering tool-dsc05185_1600x1200.jpg Lathe roller centering tool-dsc05188_1600x1200.jpg
    Lathe roller centering tool-dsc05189_1600x1200.jpg Lathe roller centering tool-dsc05191_1600x1200.jpg Lathe roller centering tool-dsc05192_1600x1200.jpg
  2. The Following 9 Users Say Thank You to rendoman For This Useful Post:
    Andyt (Feb 14, 2019), emu roo (Mar 6, 2026), Paul Jones (Feb 19, 2019), PJs (Feb 17, 2019), Scotty1 (Feb 13, 2019), Seedtick (Feb 13, 2019), that_other_guy (Feb 18, 2019), Tonyg (Feb 14, 2019), Toolmaker51 (Feb 13, 2019)
    Sep 2015
    Sandy, OR
    How does it work?
  4. The Following User Says Thank You to mudnducs For This Useful Post:
    Nov 2015
    Italy
    rendoman's Tools
    This type of tool could be useful in order to center a part inside the lathe chuck. Applying a light pressure on the bearing (against the part) it makes the bearing spin , the combination help the part find the center.
    Unluckily it's late night and I can't run my lathe for fast video, I put a YouTube video pretty useful to see how it works
  6. The Following 4 Users Say Thank You to rendoman For This Useful Post:
    dietmar g (Oct 11, 2022), emu roo (Mar 6, 2026), PJs (Feb 17, 2019), that_other_guy (Apr 14, 2019)
    Sep 2015
    Sandy, OR
    thanks!!!!
  8. The Following User Says Thank You to mudnducs For This Useful Post:
    Thanks rendoman! We've added your Lathe Centering Tool to our Lathe Accessories category,
    as well as to your builder page: rendoman's Homemade Tools. Your receipt:
  10. The Following 2 Users Say Thank You to DIYer For This Useful Post:
    emu roo (Mar 6, 2026), melbakid (Mar 11, 2021)
  11. #6
    Nov 2015
    Southwest Idaho
    Thanks for posting! Very nice and simple tool to make the job easier and safer.
    There are only two kinds of tools: Those we need and those we want!
  12. The Following 2 Users Say Thank You to melbakid For This Useful Post:
    emu roo (Mar 6, 2026), rendoman (Mar 11, 2021)
  13. #7
    Nov 2015
    Italy
    rendoman's Tools
    I'm glad you like! It's very inexpensive, I built with scraps I had at home
  14. The Following 2 Users Say Thank You to rendoman For This Useful Post:
  15. #8
    Feb 2022
    I guess I am not the sharpest tool in the shed. I still don't understand, the original post showed you using a piece of hex and a bearing from a scooter. The bearing is pressed on to the end off the hex bar. In the above video I do not see the hex bar and the bearing is mounted sideways with a bolt. What am I missing here?
    ShanerP
  16. The Following User Says Thank You to shanerp For This Useful Post:
  17. #9
    Nov 2015
    Italy
    rendoman's Tools
    Both work in the same way, no matter where the shaft is locked, the outer race of the bearing has to touch the not centered object. The guy in the video made the tool on axis with lathe spindle, my tool is perpendicular. About the bar, I had no square steel scraps available, Hex was pretty good for the purpose, a very strong shaft and easy to machine. Same for the bearing, a good one is ok.
  18. The Following User Says Thank You to rendoman For This Useful Post:
  19. #10
    Feb 2022
    I understand now! Thank you for sharing this tool, what a fantastic idea!!
  20. The Following User Says Thank You to shanerp For This Useful Post:
