Results 1 to 7 of 7
Thread: Lathe shaft sanding technique - GIF
Hybrid View
    Lathe shaft sanding technique.
    Knurling a shaft - GIF
    Machining a large shaft - GIF
    Threading a large shaft - GIF
    allenz (May 18, 2026), lassab999 (Aug 18, 2023), nova_robotics (Aug 17, 2023)
    greenie's Avatar
    Dec 2018
    greenie's Tools
    Why waste time putting it in the toolpost, why not just hang onto each end and do the same movement but by hand ?
    You don't need to be "Einstein" to make it easier on yourself, but then again, some are much thicker than others, eh.:-)
  4. The Following User Says Thank You to greenie For This Useful Post:
    Wildwilly (Aug 17, 2023)
    Dec 2017
    NeiljohnUK's Tools
    Quote Originally Posted by greenie View Post
    Hand held risks entrapment, we had a very near miss in the workshop at work, other weren't so lucky, so we banned ANY handheld abrasive or polishing, what we do at home is at our own risk, employers however cannot afford such risks being taken, especially with the likelihood of serious fines from ignoring Governmental H&S guidance/advice. https://www.hse.gov.uk/engineering/lathes.htm
    Isambard's Avatar
    Aug 2019
    Hawke's Bay, New Zealand
    I'd be more impressed, if the lathe ways had been covered.
    hemmjo's Tools
    Need a way to use more the that one stop on the abrasive. Like when you do it by hand.
  8. The Following User Says Thank You to hemmjo For This Useful Post:
    hemmjo's Tools
    Giving this some further thought. That could be a bit like an external hone. There would be constant pressure between the surfaces. High spots would be cut down, low spots would be skipped. Adding some honing oil would help remove material from between the surfaces. The surface finish would be constant due to the power feed. I can see it would be useful in some situations.
  10. #7
    Aug 2020
    and in no time the sandpaper is clogged up and or whore out.
