Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Lathe taper turning attachment
    Supporting Member brianhw's Avatar
    Dec 2015
    brianhw's Tools
    Sorry, Charron63, I didn't draw up any plans for this - (other than a few doodles on the back of a cornflakes box at the time !). Having said that, if there are any dimensions of this particular device that would assist you in making one, please feel free to ask.
  2. #12
    Apr 2016
    with all the super cheep linner ball bearings&rods nowdays this would be a cheep addition to any lathe.even my cheep9x20 enco.....I may just have to make one....good post!!!
    Dec 2015
    brianhw's Tools
    Quote Originally Posted by madokie View Post
    it seems simple and very usefull and adapable to any lathe, i have one question, how do u disconnect the threaded crosslide shaft, so crossslide follows taper shaft?? i watched vid, crossslide handle did not move.
    The cross slide nut is disconnected by removing its attachment allen screw, thus allowing the cross slide to move freely in and out.
    Hope that (belatedly) answers your question.
  4. #14
    Dec 2015
    brianhw's Tools
    Quote Originally Posted by Charron63 View Post
    Brian
    Are there any plans drawn for this? it would be awesome to have a set of tech drawings for this. I have a 10x22 grizzly lathe I love but it is a bit ruff on turning tapers of any kind.
    I didn't make any plans because I thought that there would be too many variations between lathes to do this. You should be able to come up with something suitable for your particular machine by examining the video closely.
  5. #15
    Supporting Member Hans Pearson's Avatar
    Jan 2017
    I have been planning a taper attachment like this for my Myford ML7 for ages. I have the shaft from a McPherson strut that I have removed the shoulder on, but that is as far as I have got. Several parts of the strut could go into the manufacture of this attachment.
  6. #16
    Feb 2018
    I have found that its hard to get a smooth finish moving carriage feed by hand; using power the finish comes out very smooth. I was cutting a 6° taper using the compound. Feeding by hand no matter what I tried I could not get a smooth even finish.. I rigged up a driveshaft from the end of the lead screw to the compound, what a difference!!
  7. The Following User Says Thank You to seb fontana For This Useful Post:
    motorhead (Aug 5, 2024)
