I’ve seen lots of various types of lathe tool height setting aids. They all work, but I find them either a little too awkward to use, sometimes a little less than accurate or too complicated. I developed a system to help with adjusting tool heights accurately and easily.
This idea is similar to there concept of using a dead centre in the tail stock but I find that a slightly awkward and inaccurate method.
I started with replacing all of the tool height adjustment nuts on my quick-change tool holders. I find the round knurled nuts supplied with tool holders to be difficult to adjust because you can’t use a spanner to tighten or loosen them. I used 1 inch hex brass bar (which matches several nuts on my lathe) to create hexagonal adjustment nuts with an M10x1 thread.
This allows for easier adjustments using two spanners to lock and unlock the adjuster.
Using the same 1” hex brass bar in the lathe I cut a 60 degree taper (the angle isn’t that important) and faced off the resulting sharp point to create a 1mm diameter blunt tip. This protects the tip from being bent but also gives a visual reference of a known size to adjust tool heights.
With a tool moved up close to the brass taper I use the Magnifier function on my iPhone to zoom in very close. The Magnifier can enlarge by about a factor of 10 and makes it very easy to see clearly and avoid parallax in otherwise awkward positions. With the tip of the brass taper being a known diameter of 1mm it’s very easy under magnification to accurately estimate the amount of adjustment required in comparison to the brass tip. Using the M10 x 1 adjuster screw and hex nut on the tool holders it’s quite easy to move the tool up and down by very small, known amounts.
To assist with registration of the brass taper in the three jaw chuck I numbered the faces of the hex bar to correspond with jaw numbers and marked the amount of ‘stick out’ of the tool in the chuck. If, in the future, I suspect that the registration of the hex rod is no longer accurate it’s a simple matter to lightly re-cut the taper to restore accuracy.
I considered making the taper in a hardenable steel to improve durability but thought better of it. Brass means the taper can be easily recut to restore accuracy where hardened steel can only be ground.
