Originally Posted by
Paul Jones
Morsa,
I like your ideas for the Dremel tool mounting on the Unimat. I also appreciate the link to PJs website/blog.
In regards to Hemi's dilemma about not having a welder, that can be easily solved. The nut and shaft can be joined with silver soldering the steel parts (I like this old technique because it is more an art than technology) or making solid piece from aluminum (or steel) and drilling/tapping the thread using a common drill press. Spindle nose on Dremel is either 3/4 x12 or 3/4 x 16 with the 3/4x 12 being the most common. Buying the HSS tap is the most expensive part of the whole assembling but the tap will last you a lifetime for other Dremel adaptation projects.
Regards,
Paul Jones
