Results 1 to 7 of 7
Thread: Lathe Way Wipers
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Lathe Way Wipers
    The lathe way wipers were missing on my used 12”x37” geared-head gap bed lathe. However, the lathe carriage had four pairs of 10-24 threaded holes for mounting the wipers. The holes varied slightly in position heights but already drilled and taped for use. My lathe was built in 1987 in Taiwan and is very similar the import lathes from Grizzly so I ordered my replacements for the hard rubber wipers from Grizzly. When the parts arrived, I discovered the shape of the molded "squeegee" for the V-shape and right angle sections of the ways were correctly shaped but the attachment holes were in the wrong places.
    I made my own wiper retaining plates from 1/8” thick aluminum and drilled to fit the existing treaded holes in the lathe carriage. The aluminum plates were milled to fit and I added angle plate coverings for the flat wipers. Due to the the slightly uneven heights of the previously drilled holes in the lathe carriage, I used Heimann transfer screws to precisely locate the matching holes in the new aluminum retaining plates. The retaining plates are held in place using 10-24 stainless steel Button Head Socket Cap Screws. One of the photos shows the original Grizzly "squeegee" and steel plate compared to the aluminum plates and modified rubber wiper. If I had to do this again, I think it would have been easier to make the rubber wipers from 1/8” thick rubber sheet. That will be another project when these need replacement.
Name:	Installed Lathe Way Wipers.jpg
ID:	3126   Click image for larger version.
Name:	New Lathe way wiper with top cover.jpg
ID:	3127   Click image for larger version.
Name:	New lathe way wiper wo top cover.jpg
ID:	3128   Click image for larger version.
Name:	Assembled Lathe Way Wiper.jpg
ID:	3129   Click image for larger version.
Name:	Locating Holes with Heimann Transfer Screws.jpg
Name:	Original lathe way wiper threaded holes.jpg
ID:	3132   Click image for larger version.
Name:	Factory and modified lathe horizontal way wipers.jpg
  2. The Following User Says Thank You to Paul Jones For This Useful Post:
    kbalch (Apr 1, 2015)
