Results 1 to 10 of 17
Thread: leadscrew protection
    Jun 2018
    Stevohdee's Tools
    Hey guys,
    Been thinking about leadscrew covers for some time now. Looked at all the systems online but couldn't seem to find a suitable, cheap solution. This is what I came up with... cheers
    leadscrew protection-screenshot_20190911_140200_com.huawei.himovie.overseas-large-.jpg
  2. The Following 18 Users Say Thank You to Stevohdee For This Useful Post:
    Alan Purdy (09-16-2019), baja (09-12-2019), Dbj58 (09-12-2019), Drew1966 (09-11-2019), Inner (09-11-2019), jjr2001 (09-15-2019), Jon (09-11-2019), lavern s (09-14-2019), Maszynotwór (09-15-2019), Miloslav (09-12-2019), rlm98253 (09-11-2019), Seedtick (09-11-2019), shopandmath (09-11-2019), threesixesinarow (09-11-2019), Tonyg (09-12-2019), Tule (09-12-2019), volodar (09-17-2019), walgui (09-16-2019)
    shopandmath's Avatar
    Jun 2019
    Kitchener ON,CA,
    shopandmath's Tools
    good idea :-)
    Oct 2018
    leadscrew cover
    how would you use the threading dial ?
    Dec 2018
    Unless your using a GRINDING attachment on the lathe, then why bother with leadscrew covers AT ALL ?
    Seems to be a waste of time making them, so what does steel, brass, or even wood-dust do to the leadscrews?
    skibo's Tools
    The only improvement to His design I could do, is to cut a nylon washer while He was turning the couplers to put on each end to better hold the saran wrap and act as a bushing at the ends! Other than that I might be looking into making one my self, as I do not cut threads on my 12x36 Atlas and I hate to turn wood, with all the oiled surface's and all!
    Jun 2018
    Stevohdee's Tools
    Quote Originally Posted by metal2u View Post
    Simply pull the spring back to rest behind the dial, you'll lose a bit of protection but that part of the leadscrew doesn't get much swarf anyway. I have a dial but don't use it, I get less failures with the always engaged method, cheers
  8. #7
    Jun 2018
    Stevohdee's Tools
    Quote Originally Posted by greenie View Post
    Good point but seeing "real" lathes nowadays all seem to have covers there must be something to it. I tend to use my tool post grinder quite a bit so I'm ready for anything, cheers
  9. #8
    Jun 2018
    Stevohdee's Tools
    Quote Originally Posted by skibo View Post
    Hey skibo, did think about putting washers on other ends but they don't move so I didn't think it nessesary , cheers
  10. #9
    Jun 2018
    Stevohdee's Tools
    I've just ordered smaller springs, 20 od, 1mm thick, to reduce bowing. And rather than press washers on the inside, attach on the outside diameter. The reason I chose 25mm springs in the first place was to have enough clearance to mount washers inside. This I feel will work better & neater, wish I thought of this earlier... Oh well haha
  11. #10
    Content Editor DIYer's Avatar
    Thanks Stevohdee! We've added your Leadscrew Protectors to our Machining category,
    as well as to your builder page: Stevohdee's Homemade Tools. Your receipt:
