Thread: Led holder Mk2 - heavy duty
    Supporting Member rendoman's Avatar
    Nov 2015
    Italy
    rendoman's Tools
    Hi all!
    I built with a friend a second version of Led holder.
    i will use on my new amplifier for ESL headphone, I also have to build one for my milling machine, as main voltage indicator.
    i used solid brass, hand polished with M12 thread, 19mm dia, useful for ultrabright 6mm unit, connected to 230v single phase with cap-diode-resistor.
    Heavy and shiny, as I like. I decided to make it big because the new Esl power unit will have only the headphone connector in the right position of front panel, I needed something to balance.
    Led holder Mk2 - heavy duty-dsc04245_1600x1200.jpg Led holder Mk2 - heavy duty-dsc04240_1600x1200.jpg Led holder Mk2 - heavy duty-dsc04239_1600x1200.jpg
    Led holder Mk2 - heavy duty-dsc04229_1600x1200.jpg Led holder Mk2 - heavy duty-dsc04226_1600x1200.jpg Led holder Mk2 - heavy duty-dsc04222_1600x1200.jpg
    Led holder Mk2 - heavy duty-dsc04220_1600x1200.jpg Led holder Mk2 - heavy duty-dsc04217_1600x1200.jpg
  2. The Following 8 Users Say Thank You to rendoman For This Useful Post:
    CookieCrunch (Jun 2, 2018), Jon (May 31, 2018), n9dug (Jul 16, 2020), PJs (Jun 1, 2018), rlm98253 (May 31, 2018), Seedtick (May 31, 2018), Syko Triker (May 31, 2018), Tuomas (Jun 1, 2018)
    May 2017
    Hi Randoman, nice work! Can You show the item in the "used case", possibly including the LED? Thanks a lot - Jupp
    Nov 2015
    Italy
    rendoman's Tools
    Hi! The new amplifier is not finished, since I need crucial components in order to finish the frame.
    I build another amplifier for speaker, with a similar led holder, that's the result
    Homemade Amplifier Housing - HomemadeTools.net
    Led holder Mk2 - heavy duty-32286658_10215981444791670_693145775261089792_o.jpg Led holder Mk2 - heavy duty-32238586_10215981439311533_7754742389855485952_o.jpg
  5. The Following User Says Thank You to rendoman For This Useful Post:
    PJs (Jun 1, 2018)
    Thanks rendoman! We've added your LED Holder to our Machining category,
    as well as to your builder page: rendoman's Homemade Tools. Your receipt:
    Aug 2012
    Australia
    desbromilow's Tools
    you say "ultrabright 6mm unit, connected to 230v single phase with cap-diode-resistor. "
    what values are you using?
    why the capacitor? (I can understand the resistor and diode.... is the cap to reduce the dimming during the missing half wave?)
    ta
    Des
    Nov 2015
    Italy
    rendoman's Tools
    Hi! The cap with AC should acts like a sort of resistor, because of the capacitive reactance. I used 0,01uF 400v poly , 1n4007 diode and 750 ohm resistor for UV led
