Results 1 to 10 of 17
Thread: Lever Action Clamping Screws
  1. #8
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Hi Paul, very nice job !
    I see you are using your lever screws on the sides of the dovetails of your slides. I suppose it is for pressing the wedges that serve to reduce the play in the dovetail ?
    This is something that I have a lot of difficulty to setup on my Chinese lathe.
    You seem to have one single screw for that where I have several little set screws (so tiny head that they will end up to be worn sooner or later), and they are locked using a slim nut.
    I feel my slides are whether too loose, and I have vibrations or even worse, I sometime see the tip of my cutting tool rolling under the piece .... Or I have them too tight, so with no play, but the cranks become difficult to turn ...
    Could you provide an advice on how to setup properly these screws ? Maybe I should replace them right now by scews with heads or knurled buttons like you.
    I don't see any locking nut on your screws ? no need for that ?
    Thanks in advance !
    Christophe
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    PJs (Nov 3, 2015)
