Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: LFV - Low Frequency Vibration
    Supporting Member machining 4 all's Avatar
    May 2020
    machining 4 all's Tools
    In the drawing I posted earlier, you can see the directions (marked with arrows) where the vibrations can be performed.
  2. #12
    hemmjo's Tools
    Ah I see, interesting stuff...
    https://www.citizenmachines.com/lfv-technology
  3. #13
    May 2020
    Unfortunately the price of this machine model is very high compared to a conventional CNC machine, for example ...
  4. #14
    Elizabeth Greene's Tools
    When I do an intermittent cut with carbide I break a lot of tools. Is that a problem with this technology?
  5. #15
    hemmjo's Tools
    There are many different grades of carbide. I also have trouble chipping carbide cutters when using my lathe. If I have to remove a lot material, on a lot of parts, I use carbide. Most everything else I use High Speed Steel, I can sharpen it, hone it and get good finish in many situations. I have only needed carbide for one job, so I am no expert in the topic.
    I have also used a machine to remove carpet glue from a concrete floor the size of a basket ball court. That machine had carbide cutters. They never chipped. Stump grinders also use carbide and often come into contact with rocks. These two examples have to use a tougher grade of carbide.
    This site has a lot of carbide information... https://www.federalcarbide.com/modes...ear_parts.html
  6. #16
    May 2020
    In conventional turning, the chip thickness is constant (because the feed is constant). In milling, the chip thickness is variable (concordant or discordant), however the cut is intermittent. In LFV machining, the chip thickness is also variable, due to the empty cut in the tool advance and retraction. So, just choose a tenacious tool (as in milling) and there won't be so many problems with breaks.
  7. The Following User Says Thank You to machining 4 all For This Useful Post:
    Toolmaker51 (Mar 27, 2022)
  8. #17
    Entire thread thought provoking. I recall a few instances where chip control was an issue, nobody likes birdnests. Usually, considerable increase in feed rate alters it better than RPM. It's still easier generating HSS bit that works, because they cut material, compared to 'pushing' material off as per carbide.
  9. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    hemmjo (Mar 27, 2022)
  10. #18
    hemmjo's Tools
    Yes indeed, and a good HSS bit puts a lot less stress on both the part and the machine. As with everything there are pros and cons for both.
