Results 1 to 4 of 4
Thread: little welding trailer
    A few months ago I decided to get my 1972 Miller big 40 welding machine running. I hadn't used it since 2013. After cleaning the points changing the oil and filter, drained the coolant and refilled with fresh, put a battery and gas in it the thing started right up. Gas was pouring out the carb since the float had rotted off the gas tank leaked from a hole rusted in it. some of the wiring was rat or mouse eaten, and only 2 of the range selections still worked due to broken connectors, But it ran sort of.
    A new carburetor, ign. switch, choke cable, wiring from the alt to the switch removed the top cowling and gas tank repaired the broken range selections dropped on a temporary gas tank Then used it for a week to power my carbon arc gouge while working on a dozer.
    OK now I need a way to move it around instead of having to carry it with my backhoe. I built this little trailer out of scrap laying around.
    An old steering axle from a 48 Chevy truck a framework that used to hold sheet metal a couple of in the bed side toolboxes a new hitch coupler and jack a pair of 40-year-old white wall tires from a camper trailer with new inner tubes, some sheet metal from a sign I had taken down some pipe. This is what I wound up with
    baja (Jan 11, 2025)
    Supporting Member Hill Top Machine Works's Avatar
    Jun 2022
    SW Virginia
    Hill Top Machine Works's Tools
    Looks sweet. Nice job.
    YouTube channel Hill Top Machine Works.
    My shop and website: Hilltopmachineworks.com.
    Thanks Frank S! We've added your Welding Trailer to our Trailers and Towing category,
    Dec 2017
    baja's Tools
    Nice job, Frank. Some ideas for the trailer I`m building in my head for my Miller Bobcat, oxy acetylene setup, and air compressor. Been using a Harbor Freight trailer that is a bit flimsy.
    Download plans for trailers and towing tools.
