Results 1 to 9 of 9
Thread: Loader tire inflation fail - GIF
  2. The Following 9 Users Say Thank You to Altair For This Useful Post:
    Andyt (Aug 15, 2020), baja (Aug 15, 2020), clydeman (Aug 14, 2020), high-side (Aug 16, 2020), nova_robotics (Aug 14, 2020), sak778 (Sep 12, 2020), Scotsman Hosie (Aug 14, 2020), Scotty12 (Aug 15, 2020), Tule (Aug 15, 2020)
    Feb 2018
    I wonder what accellerant they used. I have seen it done with Ether Starting Fluid, without nearly that much fire. Those guys are lucky one of them was not killed or burned beyond recognition.
  4. The Following User Says Thank You to VinnieL For This Useful Post:
    Apr 2017
    Looks to me that they were tying to take the tire off. I guess they thought this might be a easyier way.
    hemmjo's Tools
    Quote Originally Posted by clydeman View Post
    Looks to me that they were tying to take the tire off. .... .
    Looks like it worked. At least no one was standing in line with the rim retaining rings.
    Sep 2018
    This kind of stuff just boggles the mind. Seriously, folks are that stupid or that unconcerned about their own lives and that of others ? I would quit before being forced to do something like that !
    hemmjo's Tools
    This practice is not all that uncommon. One of the most dangerous parts of changing tires like that is the flying steel retaining ring. It you watch the video closely, you can see they were actually being relatively safe. They had a large wheel loader parked to absorb the energy from the flying retaining ring and tire. The guy on the right was using a long bar to bump the tire, staying well back of the "blast zone". The guy on the left had a flaming rag on the end of a long stick also out of the path of the flying parts. I have to guess they worked some diesel fuel fixed with a bit of gasoline, to help with ignition, into the tire. They were both out of the "blast zone". You can see an initial "puff" around the rim of the tire as the guy on the right backs away and the retaining ring pops off. The secondary event and ensuing flames removed the tire.
    While it is certainly better to have the proper equipment to do work. When that is not possible, other solutions are used. There are places where that specialize service equipment it just not available. The trick in doing things like this is to KNOW the possible dangers and do your best to mitigate them. I think these guys did that.
    Perhaps more dangerous than this, are the guys to have all of the proper equipment but use it incorrectly.
  9. The Following 4 Users Say Thank You to hemmjo For This Useful Post:
    bob_3000 (May 4, 2024), clydeman (May 4, 2024), neilbourjaily (May 6, 2024), sak778 (Sep 12, 2020)
  10. #7
    I agree there
  11. #8
    Mar 2018
    Hoosiersmoker's Tools
    Best case scenario...
  12. #9
    Dry Gulch, Tx
    Crusty's Tools
    Satan invented those split rim wheels.
