Machine Tool Cleaning Question
My lathe and other machines are in my basement where they are safe from Ohio humidity and temperature changes. When/If I get my barn complete, I may move them out there. But for now, they are in the basement. The problem is, my wife is very sensitive to fumes. While i have installed an exhaust fan, odors still sneak into the house. I have to keep cutting fluid use to a minimum and run the exhaust fan when I nmust use them
A lot of of the materials I use are rescued/recovered/removed/recycled from old equipment. It often has a lot of rust and scale. When machining that rough surface off the rust dust gets everywhere. I now use a vacuum to capture some of it. But a lot ends up on the machine, mixes with the surface lubrication, and makes a mess. It cannot be good for the precision parts and is really dirty and ugly.
Last time I tired to get things cleaned up I used "odorless" mineral spirits in a spray bottle to rinse things down. Which worked pretty well, BUT, I sure did get into trouble!!! Wife was upset with the ODORLESS smell. Then my son came over a day or two later and asked, "why does your house stink". So, I am not doing that again.
I am looking for something to keep the machines clean without making the house stink. While searching, I found a few citrus based products. Some of the reviews are in the "too good to be true" catagory, while others say it is not any better than Dawn dish soap.
I have even considered using HOT water and Dawn to clean things up. Then air and a heat gun to dry the water.
What do others use to clean machines?
