MAGNETIC WELDING GROUND!
https://www.youtube.com/watch?v=6Z2pSUA_9zM
Thanks orioncons36! We've added your Magnetic Welding Ground to our Welding category,
as well as to your builder page: orioncons36's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-magnetic-welding-ground-2"> <img src="/uploads/250837/homemade-magnetic-welding-ground-2.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-magnetic-welding-ground-2">Magnetic Welding Ground</a> <span> by <a href="https://www.homemadetools.net/builder/orioncons36">orioncons36</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/welding'>welding</a> </div> </div> </div> </div>
Why do you need the threaded rod and the spring? If you remove the spring loaded rod and connect the ground wire directly to the steel flat bar you'll get a better ground. Those neodymium magnets are pressed hard against your workpiece (much harder than the spring loaded threaded rod) and they're good electrical conductors. I think the threaded rod and spring is holding you back.
I have a magnetic ground that's just a mag base with a ground wire hard bolted to it. It works great.
That is an interesting idea. I also wonder what the difference would be if the lead were connected directly to the flat bar. There are several magnetic clamps on the market that do use a spring and there are quite a few that do not. I would assume that on much higher amperages more surface are would be beneficial but for most uses there may not be a difference.
