Thread: Make a magnetic test indicator base
    Supporting Member xynudu's Avatar
    Dec 2015
    xynudu's Tools
    Here's a simple test indicator base that's easily made from a few items.
    Easy metal lathe project that is super handy.
    Cheers all.
    Rob
  2. The Following 10 Users Say Thank You to xynudu For This Useful Post:
    benkeller3 (Aug 15, 2017), carloski (Jul 1, 2022), Home-PC (Jul 4, 2022), jjr2001 (Aug 15, 2017), kboy0076 (Feb 4, 2024), MadTrapper (Oct 15, 2019), Paul Jones (Aug 14, 2017), rossbotics (Aug 14, 2017), Seedtick (Aug 16, 2017), uv8452 (Jul 1, 2022)
    Thanks xynudu! We've added your Magnetic Indicator Base to our Measuring and Marking category,
    as well as to your builder page: xynudu's Homemade Tools. Your receipt:
    Oct 2019
    Germany
    uv8452's Tools
    Two improvements: 1. Put 4 or 6 disk springs 'under' the the knurled nut. This allows to fine-adjust the tension of the 'clamp' so that you still can adjust the dial without losing its position after letting it go. 2. It is difficult to adjust joint and slide with just one clamping. I joined the two clamps with a kind of two-sided-bolt (head in the middle) and two knurled nuts. Then I can adjust joint and slide separately.
