https://youtu.be/kwNkb8p5Sr4
Step by step (free): https://makethingswithrob.com/making-steel-cauls/
Maybe I missed it, but why not use the alignment bolts for the clamping force as well? It would require having multiple bolt lengths or changing to threaded rod and two nuts (and washers). Stacking a a nylon washer between two steel ones would make them tighten easily. The nylon washers can take the pressure. I use them under the tuning knobs of my headless basses and guitars, which see well over 100lb of tension per string. It's not as smooth as UHMW, but doesn't mush out when tightened.
Neil
Hey Neil
I tried to keep it as simple as possible. Because of the size, and the area that it's intended to serve, I figured it would be difficult tightening as you'd be bumping into things. Still possible and you had some great ideas to go along with it, just a few thoughts I had when making them.
Thanks Make Things! We've added your Steel Cauls to our Workholding category,
as well as to your builder page: Make Things's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-steel-cauls"> <img src="/uploads/259537/homemade-steel-cauls.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-steel-cauls">Steel Cauls</a> <span> by <a href="https://www.homemadetools.net/builder/Make+Things">Make Things</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/clamp'>clamp</a> </div> </div> </div> </div>
