Another fantastic post from Rick. This makes me wonder about the possibility of blow molding softened PVC. Basically use an outside form instead of an inside.
nova_robotics (Apr 30, 2021)
For storage large plastic cable-channel also works great, just cut it into sections, glue pieces of the lid to the rear of the u-shaped channel piece and use some wood plate(particle-board, old floor laminate(amazing material, and cheap) to make fronts...
Using a piece of plate in both ends of the channel section allows you to retain the lid and make sliding lid stackable boxes..
Like this? https://www.alliedelec.com/product/p...E&gclsrc=aw.ds
I had some PVC rain gutter and tried reforming it into a square U shape. Worked nicely!
Thanks,
Rick
Rick
Thanks earz! We've added your PVC Inner Coupling to our Miscellaneous category,
as well as to your builder page: earz's Homemade Tools. Your receipt:
Thanks earz! We've added your Wireless Charging Mount to our Electronics category,
Thanks earz! We've added your Tarp Clips to our Miscellaneous category,
Tarp Clips by earz
PVC and a heat gun - I have modified PVC pipe* for various projects using this technique - and yes, you do need to be careful of fumes produced during the process. I try to do this outside with a fan blowing the fumes away. I am sure the boxes are strong but most of my applications don't require a HD box, so I just buy storage containers from D-Tree 2-3 for $1. Sorry $1.25 now.
*I modify PVC pipe to make fittings for shop-type vacuums for tools and dust collection purposes. With heat you can adjust the diameter of pipe (+ or -) to conform to your tools or connecting hoses, as required.
