Another fantastic post from Rick. This makes me wonder about the possibility of blow molding softened PVC. Basically use an outside form instead of an inside.
For storage large plastic cable-channel also works great, just cut it into sections, glue pieces of the lid to the rear of the u-shaped channel piece and use some wood plate(particle-board, old floor laminate(amazing material, and cheap) to make fronts...
Using a piece of plate in both ends of the channel section allows you to retain the lid and make sliding lid stackable boxes..
Like this? https://www.alliedelec.com/product/p...E&gclsrc=aw.ds
I had some PVC rain gutter and tried reforming it into a square U shape. Worked nicely!
Thanks,
Rick
I have added a warning at the top of the article. Thanks to nova_robotics and clinton1 for bring this to my attention. I can see that if someone was to use a torch, this could get dangerous very quickly.
Rick
What a great idea. Bin boxes get expensive in hurry. I will Be giving this a try!
Thanks earz! We've added your PVC Inner Coupling to our Miscellaneous category,
as well as to your builder page: earz's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-pvc-inner-coupling"> <img src="/uploads/248847/homemade-pvc-inner-coupling.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-pvc-inner-coupling">PVC Inner Coupling</a> <span> by <a href="https://www.homemadetools.net/builder/earz">earz</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/pvc'>PVC</a>, <a href='https://www.homemadetools.net/tag/assembly'>assembly</a> </div> </div> </div> </div>
Thanks earz! We've added your Wireless Charging Mount to our Electronics category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-wireless-charging-mount"> <img src="/uploads/248852/homemade-wireless-charging-mount.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-wireless-charging-mount">Wireless Charging Mount</a> <span> by <a href="https://www.homemadetools.net/builder/earz">earz</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/pvc'>PVC</a>, <a href='https://www.homemadetools.net/tag/charger'>charger</a>, <a href='https://www.homemadetools.net/tag/wireless'>wireless</a>, <a href='https://www.homemadetools.net/tag/smartphone'>smartphone</a> </div> </div> </div> </div>
Thanks earz! We've added your Tarp Clips to our Miscellaneous category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-tarp-clips"> <img src="/uploads/248857/homemade-tarp-clips.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-tarp-clips">Tarp Clips</a> <span> by <a href="https://www.homemadetools.net/builder/earz">earz</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/pvc'>PVC</a>, <a href='https://www.homemadetools.net/tag/clip'>clip</a> </div> </div> </div> </div>
PVC and a heat gun - I have modified PVC pipe* for various projects using this technique - and yes, you do need to be careful of fumes produced during the process. I try to do this outside with a fan blowing the fumes away. I am sure the boxes are strong but most of my applications don't require a HD box, so I just buy storage containers from D-Tree 2-3 for $1. Sorry $1.25 now.
*I modify PVC pipe to make fittings for shop-type vacuums for tools and dust collection purposes. With heat you can adjust the diameter of pipe (+ or -) to conform to your tools or connecting hoses, as required.
