Results 1 to 4 of 4
Thread: Making counter sink nuts
    Jun 2018
    Hi All!
    I'm making a folding tripod using 1x3 triangle as legs. legs will unfold around a steel tube when set up. When not the legs will fold flat-ish.
    There are two pairs of hinges on each side of the middle leg on top and bottom; think a M or W where the other two legs can swing in & out
    I need through-bolts since wood screws won't work, but the hex nuts would interfere when closed, so
    counter sink nuts! :-)
    I chucked a 10-32 screw into my trusty ShopSmith 10-ER, jammed a couple of nuts close to the end, a washer, then the soon-to-be-conical nut last
    The middle nut suffered on the 1st attempt, hence the washer. So
    The washer is quite handy as a file guide, and a way to unscrew the cone. Here's the result
    Yes McMaster has counter sink nuts; at US$13 a pop
    Enjoy!
    Doug
  2. The Following 5 Users Say Thank You to saintrain For This Useful Post:
    ductape (May 11, 2024), Inner (May 15, 2024), Jon (May 11, 2024), Ralphxyz (May 14, 2024), thevillageinn (May 14, 2024)
    earz's Avatar
    May 2014
    earz's Tools
    That’s neat. So you’re just relying on friction of the countersink to keep the nut from spinning while tightening? A dab of valve lapping compound on the taper may provide a little more holding power if needed. Are you using any kind of thread locker to keep the screws from coming loose?
    Jun 2018
    Thanks Earz
    If friction doesn't do it (I used a pretty coarse double-cut file, so lots of nut 'teeth'), I'll just slot the nuts and modify a screwdriver to fit around the screw.
    There's not really a lot of meat in the hinge plate holes, so don't know about the loc-tite.
    Doug
    Jun 2018
    Hi Earz!
    Friction did it; snugged right up without tools or goop.
    Cones are pretty grabby, I think
    Doug
