https://youtu.be/U7lSRyV2WBc
That makes me nervous. Grinder discs rotate at a much lower rpm. A dremel or whatever rotate at a much faster rpm. Not sure the disc is safe at that speed. Sorry, not for me.
Thanks Foxtrot_! We've added your Rotary Tool Cutting Discs to our Rotary Tools category,
as well as to your builder page: Foxtrot_'s Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-rotary-tool-cutting-discs"> <img src="/uploads/225260/homemade-rotary-tool-cutting-discs.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-rotary-tool-cutting-discs">Rotary Tool Cutting Discs</a> <span> by <a href="https://www.homemadetools.net/builder/Foxtrot_">Foxtrot_</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/rotary-cutting-wheel'>rotary cutting wheel</a> </div> </div> </div> </div>
I've done this - works well and certainly lasts longer than the bought ones.
Things work fine till they don't.
You could equally apply that comment to just about any activity involving tools.
Certainly could but to stay on the subject, I'm applying that to these discs at the moment. By all means, go ahead and make and use them. I tend to suggest some heads up or warnings when I see something that makes my hair stand up. Having survived over 35 years as a mechanic without much damage at all, I tend to over think safety and what can happen if one doesn't pay attention. This will be my last reply.
