Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Making heavy duty chain - GIF
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    I like those tongs.
    Me too, think you might be able to truly call these "Duck Bills".
    Mark Twain
  2. #12
    Aug 2016
    wizard69's Tools
    Quote Originally Posted by suther51 View Post
    I have given some thought to the issue of chain welding. I have concluded that it is a matter of least resistance, or in this case shorter distance. Less steel between the "electrodes" or clamps. Surely some current travels the long way but most must take the short path. Seems that this means that there must be extra capacity of current to get a good weld. Just my own musings.
    Eric
    Maybe but if you consider the current that goes the other way wasted energy then such welding must be inefficient compared to say a wire welding process. You would have to figure that hundreds of amps (maybe thousands) are being dumped into that large chainlink.
    Quote Originally Posted by wizard69 View Post
    But when you consider that the metal is actually being melted to be fused at the molecular level leaving no dissimilar heat effected zone no external filler metal can come close to the quality or speed of the process being used
  4. #14
    Jul 2016
    Perhaps the "wasted" current is actually heating up the entire link so that the weld so not cooled to fast, like a built in post heat?
    Eric
  5. #15
    These keep getting better.
  6. The Following 3 Users Say Thank You to Jon For This Useful Post:
    PJs (Oct 29, 2018), that_other_guy (Jan 27, 2020), Toolmaker51 (Oct 23, 2018)
  7. #16
  8. The Following 4 Users Say Thank You to Jon For This Useful Post:
    baja (Jan 28, 2020), mwmkravchenko (Jan 27, 2020), Seedtick (Jan 27, 2020), that_other_guy (Jan 27, 2020)
  9. #17
    jdurand's Tools
    Not welded?
  10. #18
    Not welded?
    If you will notice the previous links are welded this gif is just showing part of the chain building process
