Results 1 to 10 of 16
Thread: Making a motorcycle chassis or this is what tools are for.
    This a post that I have been asked to make by many forum members. At last I have got around to it.
    I have done it in the form of a PDF which can be downloaded from here
    https://motochassis.com/FileDump/Frame%20making.pdf
    Here are a few photos as a teaser.
    Making a motorcycle chassis or this is what tools are for.-startbuild04.jpg Making a motorcycle chassis or this is what tools are for.-boringheadstock01.jpg Making a motorcycle chassis or this is what tools are for.-frame14.jpg Click image for full size.
  2. The Following 31 Users Say Thank You to tonyfoale For This Useful Post:
    baja (Oct 1, 2019), Beserkleyboy (Oct 6, 2019), DIYer (Sep 29, 2019), Duke_of_URL (May 30, 2024), emu roo (Mar 20, 2026), freddo4 (Jun 16, 2022), Gromet (Oct 1, 2019), hansgoudzwaard (Sep 30, 2019), Hopefuldave (Feb 6, 2020), Jon (Sep 29, 2019), KustomsbyKent (Sep 30, 2019), Little Rabbit (Jul 17, 2022), madmick77 (May 7, 2020), MadTrapper (Jun 16, 2022), markcawston (Sep 30, 2019), Moby Duck (Sep 30, 2019), olderdan (Sep 30, 2019), Papa Bill (Oct 5, 2019), Philip Davies (Mar 21, 2026), Quinton 357 (Oct 6, 2019), rayh__ (Apr 12, 2023), Resident114 (Jun 16, 2022), Rikk (Oct 1, 2019), rlm98253 (Sep 30, 2019), Saltfever (Sep 30, 2019), tommythacker (Feb 9, 2023), Tonyg (Oct 7, 2019), Toolmaker51 (Sep 30, 2019), Wildwilly (Nov 18, 2021), Wmrra13 (Oct 1, 2019), wolle (Sep 30, 2019)
    Thanks tonyfoale! We've added your Motorcycle Frame Fabrication to our Motorcycle category,
    olderdan's Tools
    Fascinating build log Tony, your attention to detail is inspiring. Looking forward to seeing more of your new engine build,
  6. The Following User Says Thank You to olderdan For This Useful Post:
    Alan,
    Not much progress on the engine. It was a long hot summer, too hot to spend much time in the workshop. So I tried to stay cool working in my office, catching up on some software upgrades and some workshop related programming and electronic gizmos, as well as preparing a new version of the book.
    A year or two ago I bought a 1 micron linear encoder for a cam profile measuring device. it didn't get a lot of use, how many cams does one need to measure? I thought that the addition of an LCD display would let me turn the encoder and its black box into a general purpose accurate comparator. When used for cams there is no need for the display because the data is shunted off to a PC for analysis. I added a switch to change functions from one to the other. Here are some pix.
    Making a motorcycle chassis or this is what tools are for.-cammeasuring01.jpg Making a motorcycle chassis or this is what tools are for.-dsc_1885.jpg Making a motorcycle chassis or this is what tools are for.-dsc_1826.jpg Click images for full size.
  8. The Following 3 Users Say Thank You to tonyfoale For This Useful Post:
    emu roo (Mar 20, 2026), rlm98253 (Sep 30, 2019), Tonyg (Oct 7, 2019)
    Sep 2019
    Brazing?
ID:	31360 Click image for larger version.
ID:	31361 Click image for larger version.
ID:	31362 Click image for full size.
    Always curious about brazing. For the life of me, I don't see how it's as strong as welding. Sure is pretty, though.
  10. The Following User Says Thank You to steveofthenw For This Useful Post:
  11. #6
    Dec 2014
    South Dakota
    KustomsbyKent's Tools
    Steveofthenw,
    As Tony explains in his document, brazing has some advantages for fatigue and vibration dampening, as well as not taking so much heat into the tube.
    While it isn't as strong as a steel filler metal would be for Oxy-Acet or TIG welding, the weld bead can be larger which helps add additional material to make up for the lower strength, and because it is a lower temperature there is less chance of burning through the thin-wall tubing and lessening distortion, which is pretty critical on a racing bike.
    If you have a torch, pick up some flux coated brazing rod and give it a try... it is more like soldering than welding though as you tend to heat the filler metal and puddle it on rather than making a puddle on the base material and dipping into the puddle.
    You can use Oxy Acetylene or Oxy Propane or the electric arc on the TIG welder.
    Plus, Brazing is just fun welding as well!
    Altho I just like welding... especially Tig, and Brazing, and MIG and stick. Not so much on flux core because of all the spatter.
    Thanks to Tony for posting that nice write-up, quite helpful for anyone building a frame and would like to minimize distortion and maintain accuracy. Lots of good building practices and helpful tips and tricks.
    For tube notching, I prefer to use my abrasive tube notcher, and second choice would be the end milling operation. Hole saws are my last choice... rough cut and hard to creep up on the fit. I have used hole saws on large tubes for fitting 2x3 square up to 2" round with 1/4" wall thickness.
  12. The Following User Says Thank You to KustomsbyKent For This Useful Post:
  13. #7
    Quote Originally Posted by steveofthenw View Post
    It is the strength of the structure that is important, do not get bogged down with the strength of an individual weld.
  14. The Following 5 Users Say Thank You to tonyfoale For This Useful Post:
    emu roo (Mar 20, 2026), Hopefuldave (Feb 6, 2020), marksbug (Dec 30, 2024), Rikk (Jul 19, 2022), Tonyg (Oct 7, 2019)
  15. #8
    Supporting Member Wmrra13's Avatar
    Jan 2015
    Wmrra13's Tools
    This is great, thanks Tony!
  16. The Following User Says Thank You to Wmrra13 For This Useful Post:
  17. #9
    olderdan's Tools
    Alan,
    Hi Tony, yes I have been aware of the high temperature in Spain & Portugal this year. I once bought a villa in Almeria with the idea of moving there, circumstances at home delayed that for too long so I sold it. The way things turned out I think it was for the best, I do miss the Spanish way of life however but the idea of lounging poolside all day would drive me nuts, I have to have a workshop to keep me sane.
  18. The Following User Says Thank You to olderdan For This Useful Post:
  19. #10
    Lounging by the poolside is not a part of my routine, I do not even have a pool. It is not really the spanish way of life either, it is more like the way of life of the northern europeans who move or holiday here. Geriatrics with nothing else to do.
    BTW. the Almeria race track is my all time favourite track.
  20. The Following 2 Users Say Thank You to tonyfoale For This Useful Post:
    emu roo (Mar 20, 2026), marksbug (Dec 30, 2024)
