Congratulations tonyfoale - your Motorcycle Chassis Fabrication Method and Tools are the Homemade Tool of the Week!
Great work! This was another busy week and difficult to win, but this was a clear winner this week.
Some more nice tools from this week:
Pulley Making Setup by liberal
Lathe Slotter by Me2
Welding Gun Spool Modification by Frank S
Stainless Pipe Bender by Let'sLearnSomething
QCTP by celsoari
Pipe and Tubing Welding Jig by Kwandotechnic
Drum Sander by Christofix
Starrett Hole Attachment Adapter by bobneumann
Belt Grinder by Making Stuff
Welding Cart Wheel Modification by Captainleeward
Scrapers by Salix84
Float Lock Vise by Retro Steam Tech
Water Pump by Mr.DK DIY
Thin Wood Slicing Jig by Make Things
Furnace Burner by SculptyWorks
12V Soldering Iron by mariost
tonyfoale - We've added your tool entry to our All Homemade Tool of the Week winners post, and you'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and award choice and I'll get it sent over right away.
More importantly, this is your 10th Homemade Tool of the Week win! I've just added the golden wrench-on-pedestal graphic to the awards showcase in your postbit, visible underneath your avatar.
:rocker: :clapping: :thumbsup: :bow:https://www.homemadetools.net/forum/...OfTheWeek1.png:bow: :thumbsup: :clapping: :rocker:
You join these four other 10-time winners: rossbotics, mklotz, Vyacheslav.Nevolya, and Tuomas. Congratulations again and good job :thumbsup:
Here are all 10 of your Homemade Tool of the Week winning tools:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/home-made-horizontal-milling-machine-55333#post81620"> <img src="/uploads/162905/homemade-horizontal-milling-machine-2.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/home-made-horizontal-milling-machine-55333#post81620">Horizontal Milling Machine</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/mill'>mill</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/grinding-machine-drum-brakes-55587#post82147"> <img src="/uploads/162657/homemade-drum-brake-grinder.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/grinding-machine-drum-brakes-55587#post82147">Drum Brake Grinder</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/grinder'>grinder</a>, <a href='https://www.homemadetools.net/tag/brake-drums'>brake drums</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/shock-dyno-shock-absorber-dynamometer-56478#post83755"> <img src="/uploads/163993/homemade-shock-absorber-dynamometer.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/shock-dyno-shock-absorber-dynamometer-56478#post83755">Shock Absorber Dynamometer</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/suspension'>suspension</a>, <a href='https://www.homemadetools.net/tag/measurement'>measurement</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/valve-holding-measuring-collet-58294#post87183"> <img src="/uploads/166061/homemade-valve-holding-collet.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/valve-holding-measuring-collet-58294#post87183">Valve Holding Collet</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/valve'>valve</a>, <a href='https://www.homemadetools.net/tag/holder'>holder</a>, <a href='https://www.homemadetools.net/tag/collet'>collet</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-laser-aligner"> <img src="/uploads/168729/homemade-laser-aligner.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-laser-aligner">Laser Aligner</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/alignment'>alignment</a>, <a href='https://www.homemadetools.net/tag/laser'>laser</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/double-edged-fly-cutter-63995#post100445"> <img src="/uploads/205514/homemade-double-edge-fly-cutter.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/double-edged-fly-cutter-63995#post100445">Double Edge Fly Cutter</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/flange'>flange</a>, <a href='https://www.homemadetools.net/tag/fly-cutter'>fly cutter</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/homemade-vertical-bandsaw-66678#post108045"> <img src="/uploads/211089/homemade-vertical-bandsaw-5.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/homemade-vertical-bandsaw-66678#post108045">Vertical Bandsaw</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/bandsaw'>bandsaw</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/diy-surface-grinder-67127#post109600"> <img src="/uploads/212251/homemade-surface-grinder-11.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/diy-surface-grinder-67127#post109600">Surface Grinder</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/grinder'>grinder</a>, <a href='https://www.homemadetools.net/tag/surface'>surface</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/radius-gauge-reverse-engineering-70673#post123621"> <img src="/uploads/219843/homemade-radius-gauge-3.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/radius-gauge-reverse-engineering-70673#post123621">Radius Gauge</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/gauge'>gauge</a>, <a href='https://www.homemadetools.net/tag/radius'>radius</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/making-motorcycle-chassis-what-tools-75470#post142830"> <img src="/uploads/226725/homemade-motorcycle-frame-fabrication.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/making-motorcycle-chassis-what-tools-75470#post142830">Motorcycle Frame Fabrication</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/motorcycle'>motorcycle</a>, <a href='https://www.homemadetools.net/tag/frame'>frame</a> </div> </div> </div> </div>
