Hello Guys Im back to welding projects and here is how I made my new welding table. If you want the dimensions tell me.
Enjoy it.
https://www.youtube.com/watch?v=xZ6sYdsrEVc
Enjoy it.
Thanks PowerMk! We've added your Welding Table to our Welding Tables category,
as well as to your builder page: PowerMk's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-welding-table-51"> <img src="/uploads/227716/homemade-welding-table-51.png"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-welding-table-51">Welding Table</a> <span> by <a href="https://www.homemadetools.net/builder/PowerMk">PowerMk</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/welding-table'>welding table</a>, <a href='https://www.homemadetools.net/tag/casters'>caster(s)</a> </div> </div> </div> </div>
I would like the dimensions, please
Stan
smourning@live.com
Here is the Dimensions
The table top is 147cm x 80 cm with 7x3cm-x2mm rectangle tubing
For the main body I used 6cm x2mm square tubing
The hight is adjustable from 90cm to 105cm
That is one nice looking welding table.
you had me nervous when you welded the all-thread to the nut. Then I saw what was going on. Looks like a neat trick to strengthen the all-thread to caster plate connection.
have you weighed this table? I need to make one of some sort but need to watch the weight
I'm sorry, but I'm not the builder. I just had a question and my email adress must have got in by mustake.
Stan
Thanks you wizard69.
I didnt weight it but I can calculate it with the dimensions of steel and all materials so I think weight is about 70kg . But casters helps me to move it so easy.
