Results 1 to 7 of 7
Thread: Making railings from concrete - GIF
Hybrid View
    May 2024
    Making railings from concrete.
    Bending stair railing - GIF
    Cracked glass stair railing - GIF
    Curved railing bending jig - photo
    Lavish wrought iron newel and railing - photo
  2. The Following 5 Users Say Thank You to ToolTalkBot For This Useful Post:
    Inner (Sep 29, 2024), nova_robotics (Sep 29, 2024), thadrodgers (Sep 29, 2024), tuchie (Sep 29, 2024), Tule (Sep 29, 2024)
    hemmjo's Tools
    That is fascinating!!!
    Supporting Member thevillageinn's Avatar
    Jul 2017
    thevillageinn's Tools
    What do you guys think is the purpose of the hose on the far end which is disconnected just before she pulls the whole thing off to remove the mandrel? It seems like water comes out of it and the hose looks clean…I had been wondering if it was providing some vacuum to remove air bubbles…but if that was the case I wouldn’t have figured it would be so clean?
    hemmjo's Tools
    Quote Originally Posted by thevillageinn View Post
    I am wondering if that hose provides water to rinse and lubricate the "bearing" on the far end. It would not take long for the sand an grit to wear out whatever kind of bearing that is running on.
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    That is not a railing, that is a Baluster, the thing that holds up a railing or beam or other capping object.
    Also, that looks like mortar, not concrete. Concrete has gravel...
    hemmjo's Tools
    Quote Originally Posted by BuffaloJohn View Post
    That very well be a type of mortar, BUT not because of the absence of larger aggregate.
    The real different between concrete and mortar is the addition of lime to mortar. Adding lime to mortar can enhance its workability, flexibility, and durability. Lime has a beneficial effect on the plasticity and cohesiveness of the mortar, making it easier to work with and reducing the risk of cracking.. https://www.graymont.com/en/markets/...nt-lime-mortar
    Concrete does typically have larger agggregate than mortar, but not always. The real difference is the lime.
  8. The Following User Says Thank You to hemmjo For This Useful Post:
    Frank S (Sep 29, 2024)
  9. #7
    Maybe the water is to cool the mandrel
