https://youtu.be/dM7HMjlSuuM
Very neat build. As you have two engines, consider splitting the rear axle between the brake disc and sprocket and installing a good fitting metal sleeve with grease nipple over the split to act as rudimentary differential to allow easier steering and less tyre wear on hard surfaces.
