Results 1 to 7 of 7
Thread: Man attempts to stop excavator swinging uncontrollably - GIF
    Altair's Avatar
    Man attempts to stop excavator swinging uncontrollably.
    Cat playing with a bird - GIF
    Excavator puts on its own track - GIF
    Excavator having seizure - GIF
    Excavator travels downhill
    excavator prepares and serves hot dog
    2000 Tool Plans 186 More Best Homemade Tools eBook
  2. The Following 4 Users Say Thank You to Altair For This Useful Post:
    mr mikey (May 31, 2023), nova_robotics (May 31, 2023), Scotty1 (May 30, 2023), that_other_guy (Jun 3, 2023)
    Sep 2013
    Karl_H's Tools
    I kept yelling at him to try the other tread!
    186 More Best Homemade Tools eBook Homemade Tools eBooks
  4. The Following 2 Users Say Thank You to Karl_H For This Useful Post:
    Ralphxyz (Jun 1, 2023), that_other_guy (Jun 3, 2023)
    Supporting Member drivermark's Avatar
    Oregon City, Or. USA
    Mighta' worked better if it were spinning the other way.
    Jul 2016
    Dont they have automatic stops if the driver is not sitting on the seat? How did he get off leaving it swinging?
    Did anyone notice this video has been flipped? the Name Kobelco is spelled backwards the operator cabin is on the wrong side
    Gadgeteer (Jun 1, 2023)
    Dec 2017
    NeiljohnUK's Tools
    Quote Originally Posted by tooly View Post
    As with most safety interlocks that become 'inconvenient' it can be by-passed, or it's simply jammed and failed. Like firearms 'safeties' its best not to entirely trust them.
  10. #7
    hemmjo's Tools
    The only three I have operated had a lever or the actual left side control arm that swung down to block the door or path to the seat. (right side in this video). You can not start the machine unless that lever or control is in the run position. I never tried to operate the controls when off the seat so I cannot say for sure if they are disabled when the safety device it raised. If you wanted to let the machine warm up at the start of a work day, you can get in, lower the device, start the machine, then lift the lever to get out. In addition, the controls "spring" back to neutral when you release the joysticks. BUT, the hydraulics on modern machines are controlled electronically so they offer very little resistance to being actuated. Either someone was playing a dangerous gag, or there was a malfunction in that system.
    In either case it may take a long time for that machine to run out of fuel, maybe a couple of days if it is full. One can run all day on a full tank doing actual work. It will just be sipping fuel running like that with no real load.
    I did think it looked odd, did not notice it was flipped until you mentioned it Frank.
    186 More Best Homemade Tools eBook 2000 Tool Plans
