Results 11 to 20 of 23
Thread: Man changes tire without a jack - GIF
    Supporting Member Skun Knuckles's Avatar
    Dec 2017
    Gippsland Victoria Australia
    Skun Knuckles's Tools
    I don’t hold out much hope for the future of the common man ��
    When I was young and poor I learnt a trade, and after many years of hard work Iím not young anymore.
  2. #12
    hemmjo's Tools
    Quote Originally Posted by mansworld View Post
    Something is fishy!... The spare tire size doesn't match the car, and the tire he is pulling doesn't look flat. He could be a wheels snatcher.
    It is only flat on the bottom...
  3. The Following User Says Thank You to hemmjo For This Useful Post:
    that_other_guy (Oct 12, 2021)
  4. #13
    Supporting Member WmRMeyers's Avatar
    Dec 2014
    WmRMeyers's Tools
    That is a "donut." It's a "cheap" alternative to a proper spare tire. They're good for taking up a bit less space in the trunk, and for getting you to a service station, slowly, and not much else. The ones I've examined closely are rated for 50 miles, and 50mph. I had to buy a new rim, and save the best of my old tires to get a proper spare for my Hyundai Elantra. And not that they are actually cheap. A replacement was quoted to me several years ago at $267 from the dealer. I paid $100 for the rim, and the mount and balance was free since I bought 2 new tires.
    Bill
  5. #14
    Mar 2018
    Not sure why the car stayed up for a second before falling?
  6. #15
    hemmjo's Tools
    Quote Originally Posted by Hoosiersmoker View Post
    Inertia. Depending on how it was parked, and the fact that tire was flat, that corner of the car was "unloaded". I think we are looking at the right rear. Most of the weight was on the left rear and right front. Typically more weight is on the front wheels, so the left front on the opposite corner was unloading that flat rear tire. That is why it did not look so squished as it might have.
    If the tire had been loaded, he would not have been able to pull it off the lugs with one hand.
  7. #16
    Jul 2016
    Someone please take his fathers DAD card away!
  8. #17
    Mar 2018
    It's the front driver side, you can see the side mirror. It doesn't come down like a tipping of the balance, it stays up then just drops like something was holding it up and it slipped out. I'm thinking he had the jack in front somewhere and when he pulled it caused the car to shift and it fell or the device holding it up failed. It looks like the car shifts toward him as it falls.
  9. #18
    hemmjo's Tools
    Ah yes, I stand corrected. I had the wrong corner.
    But I still believe the delay is caused by inertia. I used to work at an auto salvage yard. I have seen the same thing happen many times. Depending on how the suspension is loaded, one corner (wheel) can be supporting very little weight.
    After reviewing the video, I was also wrong saying that he used only one hand, If that corner had been loaded normally, he would not have been able to pull the wheel off the lugs from the bottom, even with two hands. There would be way too much friction between the tire and the ground if there was any load on that tire.
  10. #19
    Oct 2016
    old kodger's Tools
    It too couldn't believe the guy was THAT stupid.
  11. The Following User Says Thank You to old kodger For This Useful Post:
    verticalmurph (Oct 16, 2021)
  12. #20
    Jun 2018
    the load over the tire had to be lite, the lug threads alone digging into the aluminum rim would have prevented him pulling the tire away like that
