Results 1 to 8 of 8
Thread: Manual arc welding on a roof - GIF
    May 2024
    Manual arc welding on a roof.
    Arc welding slow motion - GIF
    emu roo (Jun 13, 2025), Ralphxyz (Jun 13, 2025)
    That is torch welding there is no arc when you use oxy/fuel, and it looks like lead flashing to me
  4. The Following 4 Users Say Thank You to Frank S For This Useful Post:
    baja (Jun 15, 2025), bruce.desertrat (Jun 13, 2025), mwmkravchenko (Jun 13, 2025), Ralphxyz (Jun 13, 2025)
    Perth Ontario Canada
    Who writes these captions? Cuz there is zero truth here. Frank nailed it. Soldering Lead.
    Mark
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    You can see the flame in the second pass images, it is in the reflection.
    As for who writes the captions - Ai or idiots (yes that is redundant)
    bruce.desertrat's Tools
    Quote Originally Posted by BuffaloJohn View Post
    There are plenty of Natural Idiots out there to go with the Artificial Idiots...
  8. The Following 3 Users Say Thank You to bruce.desertrat For This Useful Post:
    baja (Jun 15, 2025), Floradawg (Jun 13, 2025), Frank S (Jun 13, 2025)
    Aug 2012
    Australia
    desbromilow's Tools
    why does the welder go over the joint with a second pass? is it to smooth the bead, or some other reason?
  10. #7
    Quote Originally Posted by desbromilow View Post
    Lead gets a film of oxidation very quickly just like aluminum. If you noticed his routine, he would heat dab and back away. The rapid heating was melting the base metal from within under the layer of oxidation the dabbing while the heat was there and adding the filler material while pushing through the oxidation even though you may not have seen it. this joined the two layers but might not have made a watertight bond Since the layer of oxidation was more or less burned away now. going back over the bead would allow a nice even fluid flow.
    I used to use lead as a body filler on cars instead of the resin and hardener. Just needed a coarse grind to the metal or file it with a body file. use a lead stick and a torch heat the metal rub the stick over the surface to what was called tinning. Then melt and fill if you got too much you could heat and smooth out with a wooden paddle or file it off an remelt the filings to recover the excess lead you had used when making shapes if you needed more lead later you had to get rid of the oxidation by filing or spot heating and forcing the stick thought the layer then go back over and smooth with a paddle.
  11. #8
    Aug 2012
    Australia
    desbromilow's Tools
    thanks for the explaination
    Last edited by desbromilow; Jun 14, 2025 at 05:17 AM. Reason: glitch double posted
