Thread: Mater Slave Circuit Diagram for 2 and 3 Phase Extension
    Supporting Member 2gsg2_muc's Avatar
    Aug 2021
    Munich
    2gsg2_muc's Tools
    Master slave switch using Kemo M103N module
    When an extension is required, the question often arises as to how I can connect my machines so that not everything has to be switched on and off manually. I have now built myself an extension cable for 3 phase supply with a maximum of 16A with a Kemo M103N master slave switch. The power is supplied via a 5-pin CEE plug with 16A. A 16A CEE socket outlet and a Schuko socket outlet are available independently for the switching function, with which the slave socket outlet is supplied. Two further 2-phase sockets are connectet for direct supply. A box is required in which the sockets and the switch can be installed. The extension cable is connected directly.
    Attached Files Attached Files
    Thanks 2gsg2_muc! We've added your Extension Controller Circuit to our Electrical category,
    as well as to your builder page: 2gsg2_muc's Homemade Tools. Your receipt:
