Results 1 to 10 of 11
Thread: Melting a machine gun barrel by firing 700 rounds through it - GIF
    baja (Jan 14, 2021), nova_robotics (Jan 13, 2021), TheElderBrother (Jan 13, 2021)
    Lake Tahoe
    IntheGroove's Tools
    The full nine yards...
    Unkle Fuzzy's Avatar
    Near Monkeytown, USA
    Warranty Void
  5. The Following User Says Thank You to Unkle Fuzzy For This Useful Post:
    hemmjo's Tools
    I have to ask WHY would anyone do that? It's not like the result is any surprise at all...I guess it is ok as long as it was their money that wasted.
  7. The Following User Says Thank You to hemmjo For This Useful Post:
    Rikk (Jan 19, 2021)
    jdurand's Tools
    Bet his shoulder reminded him of this for some time.
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    That's just a suppressor - not the barrel. Suppressors are often made of very thin steel and/or aluminum. They work by slowing the gas as it exits the barrel. The side effect is that it traps the heat, too. You can see that it melted between two of the baffles near the mount where the hottest gas gets trapped.
    Neil
  10. #7
    Dry Gulch, Tx
    Crusty's Tools
    All military automatic weapons are put through similar tests before adoption to learn what the approximate failure point is. It's irresponsible to give a grunt an MG that will melt down shortly when he's in a situation that requires him to spray and pray to stay alive. The infamous German MG weapons of WWII had easily and quickly changeable barrels and the gunner always carried at least two so that a hot barrel could be swapped out to cool while continuing to lay down fire.
  11. #8
    trigger's Avatar
    Jun 2018
    Waste of good expensive bullets and a working Zombie gun.That said during the test what is interesting is the gass leakage at the barrel tap port,and the possibility at the end of the video of cook offs.If you ever needed to do the full nine yards ie 700 rounds in one go you need backup pronto or consider a tactical retreat to the rear.
  12. #9
    Supporting Member TheElderBrother's Avatar
    Sep 2019
    The Land of Cotton
    That is an excellent question. I'd be afraid of the gun blowing up in my face at that rate of abuse. Bad enough they wrecked the temper of that barrel and melted the comp/suppressor right off the muzzle. Waste of a good SAW.
  13. #10
    Oct 2014
    Liquidhandwash's Tools
    HE MISSED!
