Results 11 to 20 of 24
Thread: Metal shaper
    Vyacheslav Nevolya
    Vyacheslav.Nevolya's Avatar
    Dec 2015
    Ukraine
    Vyacheslav.Nevolya's Tools
    The bed of the metal shaper. To save kinetic energy, a large heavy flywheel is needed. In the photo, a screw 40mm in diameter and a flywheel weighing 15kg. The Metal shaper must be strong and massive .
    Metal shaper-20190723_101211.jpg Metal shaper-20190723_101220.jpg Metal shaper-20190723_101655.jpg Metal shaper-20190723_110522.jpg Metal shaper-20190723_111107.jpg Metal shaper-20190723_111132.jpg Metal shaper-20190723_111210.jpg Metal shaper-20190723_111241.jpg Metal shaper-20190723_111251.jpg
  2. The Following 7 Users Say Thank You to Vyacheslav.Nevolya For This Useful Post:
    Alan Purdy (07-24-2019), baja (07-24-2019), mwmkravchenko (07-28-2019), rlm98253 (08-23-2019), Scotty12 (08-23-2019), Seedtick (07-24-2019), Toolmaker51 (07-24-2019)
  3. #12
    Vyacheslav Nevolya
    Dec 2015
    Ukraine
    Update
    Metal shaper-20190730_110749.jpg Metal shaper-20190813_152730.jpg Metal shaper-20190813_152809.jpg Metal shaper-20190823_174502.jpg Metal shaper-20190823_174508.jpg Metal shaper-20190823_174515.jpg Metal shaper-20190823_175426.jpg Metal shaper-20190823_175454.jpg
  4. The Following 2 Users Say Thank You to Vyacheslav.Nevolya For This Useful Post:
    Drew1966 (08-23-2019), Scotty12 (08-23-2019)
  5. #13
    Vyacheslav Nevolya
    Dec 2015
    Ukraine
    Metal shaper-20190823_175956.jpg Metal shaper-20190823_180244.jpg Metal shaper-20190823_181254.jpg Metal shaper-20190823_181318.jpg
  6. The Following 7 Users Say Thank You to Vyacheslav.Nevolya For This Useful Post:
    Jon (08-23-2019), mwmkravchenko (08-24-2019), N00b Machinist (08-23-2019), Rangi (08-23-2019), rlm98253 (08-23-2019), Scotty12 (08-23-2019), Seedtick (08-23-2019)
  7. #14
    Vyacheslav Nevolya
    Dec 2015
    Ukraine
  8. The Following 4 Users Say Thank You to Vyacheslav.Nevolya For This Useful Post:
    billd (08-24-2019), Crusty (08-26-2019), MeJasonT (08-26-2019), Rangi (08-23-2019)
  9. #15
    Vyacheslav Nevolya
    Dec 2015
    Ukraine
    Metal shaper-20190913_115024.jpg Metal shaper-20190913_121956.jpg Metal shaper-20190913_122756.jpg Metal shaper-20190916_101214.jpg Metal shaper-20190916_101338.jpg Metal shaper-20190919_123503.jpg Metal shaper-20191008_141826.jpg Metal shaper-20191008_142408.jpg
  10. The Following 2 Users Say Thank You to Vyacheslav.Nevolya For This Useful Post:
    mwmkravchenko (10-10-2019), Okapi (10-14-2019)
  11. #16
    Vyacheslav Nevolya
    Dec 2015
    Ukraine
    Metal shaper-20191008_142456.jpg Metal shaper-20191008_142822.jpg Metal shaper-20191008_142831.jpg Metal shaper-20191008_143312.jpg Metal shaper-20191008_143721.jpg Metal shaper-20191008_144020.jpg Metal shaper-20191008_144802.jpg Metal shaper-20191008_145220.jpg Metal shaper-20191008_145406.jpg
  12. The Following 3 Users Say Thank You to Vyacheslav.Nevolya For This Useful Post:
    Alan Purdy (10-11-2019), mwmkravchenko (10-10-2019), Okapi (10-14-2019)
  13. #17
    Vyacheslav Nevolya
    Dec 2015
    Ukraine
  14. The Following 7 Users Say Thank You to Vyacheslav.Nevolya For This Useful Post:
    Alan Purdy (10-11-2019), baja (10-11-2019), harleyron74 (10-13-2019), jimfols (10-10-2019), Jon (10-09-2019), mwmkravchenko (10-10-2019), Okapi (10-14-2019)
  15. #18
    Dry Gulch, Tx
    Crusty's Tools
    I've studied your build quite a bit (nice work BTW) and an aspect that isn't clear to me is how the yoke attaches to the ram at the top and compensates for the changing distance between the lower pivot point and the ram's attachment point, i.e. (the distance at yoke vertical from the lower pivot to the ram attachment is shorter than that same distance when the ram is at either end of its travel). Is there a floating link (like in the Gingery shaper) that attaches the yoke to the ram and changes to compensate for the changing distance or is some other method used?
    I understand if there's a language barrier to a reply but Google Translate might be of some help.
  16. The Following User Says Thank You to Crusty For This Useful Post:
  17. #19
    Sep 2015
    Ontario Calif USA
    Very nicely documented with excellent videos. Thank you.
    Jim
  18. #20
    Awesome build. And I have been following your work. Like Crusty's post there are areas of the machine's operation that are a little hard to think through. But I am sure that you have figured this stuff out. This is making me think quite a bit of making my own Shaper.
There are currently 4 users browsing this thread. (1 members and 3 guests)
  1. LeighS
