Hello Saltfever,
Thank you for your interest!
However, I'm afraid there's not much to report. I recall using a more robust stepper interface, as the one originally implemented burned out easily...
...later, other projects and work concerns took precedence, then in 2016 the neighborhood where I live suffered a flood. As a result of that, EVERYTHING went into storage (on higher ground), and any planned changes to my version of Chuck's electronic dividing head were put on hold. Which is where it's been ever since, I'm afraid. It's like having to suddenly pack up everything you own (that didn't get wet), as if to move.
Now that I'm officially retired, and with winter rapidly approaching, your inquiry might be the incentive I need to drag it into the light once again... :)
As for the MSP430 vs Arduino thing, it's really more personal preference than anything. In a previous life, the company I worked for handed me a project which required controlling a motorized 'gizmo' with valves, using the MSP430(F149). I spent the next several months developing the firmware for it, and was completely interrupt driven. Years later, when I constructed the EDH, built around the Arduino; I didn't see an easy way of implementing interrupts (I don't recall now if 'at the time' they weren't available, or I simply didn't spend enough time researching...). Polling for a button press is simply "not to be done" in my world...
A quick search prior to replying here, shows that hardware interrupts are indeed available to the Arduino developer. I seem to recall some revisions to Chuck's original code by others, so this may have already changed as well...(?) But I need to catch up. If circumstances allow, I'll do what I can to update and make any (noteworthy) updates available here...
Hope this helps,
-EN
