Thread: Mill quill shaft nut
    The quill shaft bearings went out on my Enck bench top mill last spring and somehow, I have forever lost 1 of the shaft nuts and the remaining one has some damage, so I had been trying to locate new one for quite some time now and hadn't had any luck finding a 1.173" 20TPI left hand thread.
    I can find 18TPI in right hand. But nothing that would screw onto my mill shaft. So I decided to just make my own for these I found a cylinder of mystery stainless Hacked a lump off of it turned it down bored it and threaded it then cut the spanner groves around the outside
    It's not perfect but once it is down inside the quill, I'm the only one who will remember it
  2. The Following 7 Users Say Thank You to Frank S For This Useful Post:
    baja (Jul 13, 2025), Home-PC (Dec 14, 2021), Jon (Dec 16, 2021), LMMasterMariner (Dec 15, 2021), metric_taper (Dec 14, 2021), mwmkravchenko (Dec 16, 2021), Scotsman Hosie (Jan 15, 2022)
    Thanks Frank S! We've added your Mill Quill Shaft Nut to our Machining category,
    Jul 2018
    Flora, MS
    Floradawg's Tools
    The French call those KM nuts.
  5. The Following User Says Thank You to Floradawg For This Useful Post:
    emu roo (Jul 10, 2025)
    Supporting Member Scotsman Hosie's Avatar
    Apr 2017
    Salt Lake City, UTAH
    Scotsman Hosie's Tools
    You're the man, Frank! (Gettin' 'er done — one way or t'other.)
    Download plans for milling tools.
  7. The Following User Says Thank You to Scotsman Hosie For This Useful Post:
