Thread: Mill table slot insert covers (aluminum)
    Dec 2016
    bobs409's Tools
    I got tired of other approaches to keeping the slots clean on my mill table so I made these slip in inserts from aluminum.
    I made them so they do not go all the way to the bottom so that if there is a few "rebellious" chips in the grooves, it won't hold them up. I also made them so they sit slightly below the surface so they don't interfere when using things like a magnetic base for a dial indicator, etc.
    To aid in removal since you can't grab them, I pressed in some steel discs into the 2 outer pieces. A magnet is all that is needed to lift them up/out, then the long ones are easy to grab onto.
    Before:
    After:
  2. #2
    Thanks bobs409! We've added your Mill Table Slot Covers to our Milling category,
    as well as to your builder page: bobs409's Homemade Tools. Your receipt:
