Results 1 to 5 of 5
Thread: Mill Tramming tool aid
    jjr2001's Tools
    I read this somewhere on the net but it has been a while and I do not remember where I read it.
    My mini mill table is 4" by 16" long and with the T-slots that does not leave much room for checking tram.
    I found this Honda brake disc on the bay for $15.00 and that included shipping. Now, the thing weights
    a good bit, must be over 10 lbs and that is a good thing.These discs are precisely ground and have a nice finish.
    The one I bought has a large hub in the center section which I could do without buy my tramming tool that I made
    a while back has positions for small diameter testing and larger diameter testing since I always wanted to get a
    precision plate to aid tramming.
    Any how here are a couple of shots of the setup. Works great.
    My mill was the tilting column variety and I have it locked down. I never tilt it.
    I made mine quite sturdy using this process:
    Reducing Mini-Mill Column Flex (and Column Y-Axis Alignment) - Home Model Engine Machinist
    The bar at the bottom is the secret to a fast and accurate tram. If you have the solid column I think it has a built in set of
    stops that can be adjusted.
    Cheers, JR
    Attached Thumbnails Attached Thumbnails Mill Tramming tool aid-tram_21.jpg   Mill Tramming tool aid-tram_24.jpg   Mill Tramming tool aid-tram_25.jpg
  2. The Following User Says Thank You to jjr2001 For This Useful Post:
    eddowens (Apr 21, 2017)
    Thanks jjr2001! We've added your Mill Tramming Aid to our Measuring and Marking category,
  4. The Following 4 Users Say Thank You to DIYer For This Useful Post:
    2429nevard (Apr 27, 2017), eddowens (Apr 21, 2017), jjr2001 (Apr 20, 2017), Moby Duck (Apr 22, 2017)
    rbjracing1's Avatar
    Jan 2017
    I do the same thing with a 12" GM truck rotor on my 10 x 54 knee mill for traming
  6. The Following User Says Thank You to rbjracing1 For This Useful Post:
    jjr2001 (Apr 25, 2017)
    rbjracing1's Avatar
    Jan 2017
    Maybe I should have mentioned that I turn the rotor opposite of your picture and anchor it to the table. The rotor hub is milled true to the brake pad surface so it woks like that as well.
  8. The Following User Says Thank You to rbjracing1 For This Useful Post:
    jjr2001's Tools
    Thanks for the tip. I think I will try that just to test my x-axis ways. I have always thought that the x-axis ran up hill when I move to the right.
    The ground surface on the rotor is much smoother than the mill table so that should give good results.
    Cheers, JR
  10. The Following User Says Thank You to jjr2001 For This Useful Post:
    Captainleeward (Oct 14, 2017)
